  • Replies 640
  • Created
  • Last Reply
Top Posters In This Topic
Well I have the ramp to my self for a week so I thought I would give it a good tidying up underneath! I had not been going long when I found some suspicious bubbles in the paint on the drivers side sill. I then proceeded to scrape them off only to fined the was not a lot left at the back of the paint! So this is what I have been up to today!!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsd20f6d28.jpg.html'>null_zpsd20f6d28.jpg
A bit more prodding and it turned into this!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps620f7836.jpg.html'>null_zps620f7836.jpg
so I then cut it all out!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps55214af9.jpg.html'>null_zps55214af9.jpg
then cut this out from a card template
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps48cab4d4.jpg.html'>null_zps48cab4d4.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps41eda013.jpg.html'>null_zps41eda013.jpg
Welded in place
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps08dd9e3d.jpg.html'>null_zps08dd9e3d.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpscc602afa.jpg.html'>null_zpscc602afa.jpg
Next to plate up the top, cut this bit to go inside.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsea2a868b.jpg.html'>null_zpsea2a868b.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsee9629f8.jpg.html'>null_zpsee9629f8.jpg
All welded up!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps4e1bd470.jpg.html'>null_zps4e1bd470.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps9446eee8.jpg.html'>null_zps9446eee8.jpg
Then it was all rust cured ready for the paint in the morning!! The other side is still as good as new so im not too sure what exactly made this side go like it has apart from there been a bit of water in there.
Cheers mate! Its a good job I have because I found some more rot today!! so thats been taken care of now!
I came across this in the n/s/r corner at the back of the wheel its been getting a bit of a battering from the muck from the wheel for quite some time!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps4ff0d256.jpg.html'>null_zps4ff0d256.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps1f9676c1.jpg.html'>null_zps1f9676c1.jpg
Another cardboard template
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsa7a739ce.jpg.html'>null_zpsa7a739ce.jpg
Then cut out in steel I formed it to go round the raised shaped bit
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps5b8766c7.jpg.html'>null_zps5b8766c7.jpg
Weld through coating on gives a bit more protection
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps5cc9a128.jpg.html'>null_zps5cc9a128.jpg
Ready for welding on.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsb3673d08.jpg.html'>null_zpsb3673d08.jpg
I did get it welded and painted but forgot to take picks!! I hope this is the last of the welding! 15 years as a daily driver has started to take its toll on the old girl now so plenty of cleaning off the rust, painting and wax oiling is going on!
Cheers mate it was nice talking to you too!
Well I got some more done today got some paint on and the wax oil in the wheel arches. That should help keep it rust free!
I also got cracked on with relocating the battery to the boot, I have had the box ages now so I thought I best get on with it!
I made all new earth leads to go around the engine bay too as I have used 2 core wire for the relocation it made sense to change them wile I was doing it all.
The ones on the right are the earth and the ones on the bobbing are the poss.
The cables into the boot I will take some picks of them under the car but I forgot today.
The box!
Mega fuse on the side to be safe!
Just needs to be fastened down now!
Edited by Rob H
cracking work dude, when I did mine I linked my battery still to the fuse box in engine, as did mine quickly.lol..
and what wax oil did you use mate?
as going to do this to mine again.
  • 2 weeks later...
Got FLAPS!!!! Thanks to Carbon Goodies (RICK)
http://s87.photobucket.com/user/turbosr_2006/media/toylet/2c3e1d84-23cc-4746-9791-8d842efedf0d_zps3dcae401.jpg.html'>2c3e1d84-23cc-4746-9791-8d842efedf0d_zps
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps5e6c26e9.jpg.html'>null_zps5e6c26e9.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/004-1_zps148afb2b.jpg.html'>004-1_zps148afb2b.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsb9c895eb.jpg.html'>null_zpsb9c895eb.jpg
This is genuine Carbon too!!! sandwiched in rubber or something similar so they are very flexible.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/007-1_zps8206c70f.jpg.html'>007-1_zps8206c70f.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsea17f56c.jpg.html'>null_zpsea17f56c.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/010-1_zpsf7513db9.jpg.html'>010-1_zpsf7513db9.jpg
Ups thats my hellper
Fitting is nice and easy for every one too!! The rear brackets use one of the original liner bolts and then the 4 self tappers that come with the kit.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/016_zps7d7633c4.jpg.html'>016_zps7d7633c4.jpg
once you have them mounted hold to flap up to the bracket and mark them for the holes where you want them to go and then drill out the holes 6mm and bolt them up! I drilled one then used that as a guide to drill the second one so they end up exactly the same.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/017-1_zps1116f62a.jpg.html'>017-1_zps1116f62a.jpg
The fronts are all predrilled for ya so you just bolt the flaps to the bracket, take out the 2 arch liner bolts and bolt them on!! One thing I did have to do was cut the fronts down as they would have dragged on the floor at the length the come but this will depend on your ride height to what length you will need them.
Out of the box
http://s87.photobucket.com/user/turbosr_2006/media/toylet/015-1_zps8dcb014f.jpg.html'>015-1_zps8dcb014f.jpg
Cut down. I only took 3/4 inc off them so there still pretty low so I may take some more off them yet.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/014-1_zps0294c4ea.jpg.html'>014-1_zps0294c4ea.jpg
And the finished job!!!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/019-1_zps77018a0f.jpg.html'>019-1_zps77018a0f.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/022-1_zps2638fc81.jpg.html'>022-1_zps2638fc81.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/024-1_zps40b22d67.jpg.html'>024-1_zps40b22d67.jpg
  • 3 weeks later...
Inspiration reading through this thread! I read it quite a lot to be honest! Great car rob and a nice guy to! Appreciate your help mate with my questions :)
Well its had a bit of a transformation this weekend!!! I dropped on a mint 98spec front bumper and genuine toyota splitter in the correct black for my car from Matt ep91 glanza so then sorted out for Richdog to paint my bonnet and side skirts I have had sat about ages. Must say Richdog (Simon) has done a fantastic job of painting them for me and got them all done within the week so I could get them fitted this weekend!
So heres how it looks now!
One Glanza one N\A lol
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps486a8a49.jpg.html'>null_zps486a8a49.jpg
A pair of them!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsbe6ddc20.jpg.html'>null_zpsbe6ddc20.jpg
Bumper on for a test fit! It only needed a bit trimming off the bottom for the cooler pipes so I was happy with that!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsc380ac4a.jpg.html'>null_zpsc380ac4a.jpg
I made a tilt bracket for the number plate too.
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps8c370d98.jpg.html'>null_zps8c370d98.jpg
Skirts stuck on!! Tiger seal ftw!!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps159d0ed9.jpg.html'>null_zps159d0ed9.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps7f4fc64b.jpg.html'>null_zps7f4fc64b.jpg
The finished thing!! im well happy with the look Ive always had a thing for the 98 front end!! Just needs a good wash and polish now!
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps0a165ba5.jpg.html'>null_zps0a165ba5.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps545b0cec.jpg.html'>null_zps545b0cec.jpg
http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps75c23487.jpg.html'>null_zps75c23487.jpg
looks much better dude, one thing that bugged me about this was the fact the FMIC hung below the bumper and now its hidden :)
Great build
