Lewis's 98 Spec TD04 236bhp Beast - Update: 08/05/14 - END GAME....
I have some Pi lowering springs if you fancy them. They are really low. They do come with shocks however a couple of them a knackered
  • Replies 494
  • Created
  • Last Reply
Top Posters In This Topic
Bargain and a clean V!
I'd say go for 45 profiles, Uniroyal have released their new Rainsport 3 which I'm sure will be an awesome mid-range road tyre! (Going for them myself)
this looks so clean, plans sound good too :) will keep an eye on this
Thank you, awaiting a few parts at the moment.
@Amjad - I heard about these, to be honest I'm quite torn between Prada Spec 2's, or the toyo's.
Do you know the pricing for uniroyals new tyre?
Parades Are crap dude! Toyos aren't great either, even rainsport 2s are a lot better!
50 profiles are all cheap under £40 and 45s around £50
Hmm, I'll have to have a look into this. I ran Parada's and Toyo on my EP3.. I couldn't fault either. I felt the Toyo had the upper hand in winter!
Edited by Zeldoz
Another cheeky update, Boost gauge arrived last night. I was desperate to find out what im boosting too!
Here's how it looks, Just awaiting next thursday to order my pod pillar gauge! Currently it's wedged above the stereo.
EB6AE09C-2992-4DAE-97D9-978C14224748-257
2F52ED38-2278-4647-B5FE-4CD431AF51E3-257
Basically aimed at to get a nice colour match when i finally get indigo dials!
5A631F93-9BB6-4519-8045-0F9A59BAD43A-257
More updates soon!
So, from what i could see.
1st gear im boost around 0.4bar
2nd gear it was a solid 0.8bar
and 3rd gear i ran out of road..
So, i need to retest!
but, is that about right?.. I HAVE GOT 1 & 2 restriction STILL in place. So i thought 0.8bar is ALOT to be boosting considering its limited still.
I don't think the restriction will be in place if you are still running a adjustable actuator?!! could be wrong though
I'm still on the OEM actuator currently. The HKS one isn't fitted yet.
That actuater is dodgey mate should be only boosting .65 on standard actuater..
Get the HKS on they make a nice diffrence aswell:)
Was really suprised when i fit mine and its only boosting .7
A front mounted air filter, decat and exhaust all improve the air flow meaning the standard actuator cant hold standard pressure well. Cold weather will encourage boost creep as well.
Im not 100% but i think the hks actuator might not actually solve your issue. You may need to port your ct9's wastegate to keep the boost levels where they should be, either that or fit the standard air box back on and see if that restricts the flow to keep the boost controlled. Last thing u want is to be hitting fuel cut.
Looks really nice tho man :) absolute bargin
Thanks buddy. I'm going to do this to aid the situation and avoid fuel cut do it short term.
I dont want to spend money on this CT9 setup as i'll be going TD04 Christmas time!
So over the weekend i did the following;
  • Fitted TEIN lowering Springs
  • Fitted Flat wiper blades
  • Fitted blue silicone pipes to smarten the engine bay
I am rather confident when it comes to doing things on cars. Since i owned my Type-R i always did various things like exhaust changes, servicing, coilover adjusting etc. I hadn't ever toyed with suspension or brakes. Which i was slightly worried at first.
After a late Friday night drive to Folkestones and a mini Glanza meet there with a few lads of the forums i had bagged myself almost new TEIN suspension on standard shocks all for £35!.. I couldn't believe it. The guy wanted to shift them, and was happy to help another V owner out with a bargain!
D5AE645C-8EE5-408F-9A99-22115C8187D8-336
So late Saturday afternoon i decided to give it a go. I thought if i don't try i wont learn, and suprisingly it was easier than i imagined and in future i would be happy to do it again.
Front strut done;
729C2713-B4D2-4B30-989D-DC1FA0A89A6B-336
As you can see the springs are in mint condition, the shocks don't look brilliant. But, it's a temporary lowering solution until i can pickup some coilovers at a reasonable price.
Rears;
3B39A339-2104-435C-9D11-A931AD7E82FF-336
Can anyone point out if they are aftermarked shocks? My standard ones didn't have a blue/yellow sticker?...
Best of all.. Even the Mrs's got involved. - She's a keeper!
04E10FAC-B280-48D2-BD28-09B2CC953496-336
So this weekends little list is as follows;
  • Remove Aircon
  • Fit Front Mount Intercooler
  • Fit Air Filter Relocation Kit
  • Fit HID's
  • Paint Rocker Cover
  • Cut my MINT 98 spec bumper..
More to follow..
Don't cut your bumper, buy "Matt ep91 glanza" 's silver 98 spec front bumper with the live sports splitter. It's already been cut out for a FMIC
Link?
Will be removing the Aircon system tonight in preparation for fitting my air filter relocation kit and the front mount intercooler.
To remove the front bumper, is it just 1 bolt in each wheel arch then unclip the little plastic fasteners under the bonnet?
I do still have my plastic engine tray underneath, will this need undoing too?
I think there is two bolts beneath the bumper if I'm correct. And the splitter only looks good if you have big side skirts or it looks a bit silly
So tonight i cracked on with;
  • Removing Aircon
  • Mount Oil Catch Can​
I used a guide off the forums to remove the Aircon, i printed it off and followed it step by step. I didn't remove the pump and put the shorter belt on, mainly because i honestly couldn't be bothered. I also think i kind of didn't have the confidence to take the pump off and replace with the shorer pump etc.
I'll probably chuck it in the garage for that to be done..
9C10F4C8-F499-410A-AEE3-9CC9ED0BD32D-336
All Aircon removed. Wasn't too bad, only one annoying tight bolt ontop of the Aircon pump caused me issues and just getting the old pipes out of all the tiny nooks and crannys as they are well hidden and routed around the bay! But got there in the end.
Here's some random pictures i also too;
E0567F8C-5614-42EA-B9DE-643DA2DEFF7F-336
I also mounted my Oil catch can ready to plum in once the lovely topmount has been destroyed on Saturday! - Also excuse the snapped of old aircon pipes in the bulkhead. I coudn't find my spanner set as we've just moved house and the garage is half full from the back end! - Once i have digged them out i will whip them off.
24E720F6-CA07-4F7E-AF46-46CC0DD5F20E-336
Also moved the air filter from the corner so i could fit my Oil catch can. This will be properly relocated at the weekend!
2A1500FA-F7DE-4CFF-AB9E-52CB3350C8FD-336
More updates to follow!
So this lovely parcel showed up today... Which will take me most of the evening to squeeze into the bay i'm sure!
A9F82913-E6A1-4930-9676-4B3C817CF689-365
CC620B71-9860-4D95-970D-5F8797D2518B-365
Managed to steal a dremmel of a friend.. Will be going to B&Q later to get some heads for it!
I'll update the thread with how it goes later!
Looking good mate. I'm guessing your going to cut your bumper up then
Yeah, I will go Varis. But right now, it's not essential. I have fuel cut issues etc i need to resolve really before i go along the lines of "styling".
But i will be buying one of you guys in a few months i think.
