My White And Black, Hybrid 200bhp Fte Conversion!
  • Replies 746
and just incase anyone reading up on this knows where i can find the following, please let me know!!!!
- TPS off a gt quady or a square light if they are the same!
- A decent place to get gaskets and studs for a ct9
this realy is all thats holding progress back atm!
Jay
Jay this is really coming together now top work buddy :thumbsup:
cheers mate!! all progress has slowed down recently! bit annoying but cnt be helped!
TONIGHTS PROGRESS:
Fitted Glanza fuel pump
Fabricated brackets for front mount
Removed NA engine loom
Fitted boost gauge
Removed glove box ready for ecu's
Got a packman eating a WRX logo sticker off mike today :thumbsup: along wiv some gaskets so CHEERS MARRA!
hopefully get rest of gasket stuff soon, so oil will be able to go in and then can fit a few more parts!
NOT LONG NOW :mellow:
got the loom today from the gt! there is so much more to it than the NA lol and had a rite old chin wag with sally, Andybill, and liam D at MFN tonight.. got an awkward and frustrating week or so ahead of me with wiring ect! just want to get it over and done with now so i can get back on to the easy stuff!!!
will update soon!
oh and vote for me in POTM :mellow::thumbsup::thumbsup:
Think i may have gaskets and studs sorted with thanks to Liam D and Kierz!
made a list of each and every thing that needs doing no matter how big or small, to get this to running properly and back to normal again... 2 sides of A4 in size 12 writing!!! still miles to go lol but getting there bit by bit
hopefully will be in garage again 2moz so shud have some more updates and pics :)
lol i know :)
WIRING UPDATE:
completly removed NA wiring loom from engine bay and put in the GT one.
pluged all obvious plugs into the engine etc, ecu plugs are the same which is a bonus. but now need to find a diagram or a chart, with the colour codes for NA and GT interior loom, as they are different plugs. if they are all the same colour code as each other, then this will make life so bloody easy it wud be unbeliveable. but chances of that are SQUAT. so next step is to find out the colour codes for the looms
also drained the petrol out of it ready for v power :)
out in garage again tonight lol
managed to tick following off the list
replace all turbo gaskets
new oil filter
filled with fully synth oil
cleaned a few supporting brackets and fitted
made a prototype centre console plate to house 52mm gauge, HDI ebc-r, rocket arming switch, turbo timer
should get real thing made up tomorrow and installed! looks half decent atm :thumbsup:
nice boring update.. lol
sounds good to me so when is the lil beast gonna be running?
well only thing holding this back atm, is wiring. i need to splice the interior loom of the NON turbo with the engine loom from the GT, so the sooner i can find some form of diagram or someone who knows how to do it, the sooner this issue will be resolved! did u use the glanza engine and loom?!
best crack on with the other stuff i can do!
Jay
Jay
its alot easier to do it with the glanza looms, straight plug and play if its a pre 96 n.a
lol got bored while out in garage and thort i wud try some of the tuning parts on the lawnmower!
by the way not that chav in real life lolololol
also started to cut bumper, got a pic but dont think i guna post it yet... affraid too many will be like WAAA U NOBER. lol
*ENGINE UPDATE*
old work collegue mike from monster motorsport came accross today and gave us a hand at ticking loads off the long list!
did following:
Fitted Blitz decat
Fitted glanza radiator
Final mock up of front bumper
Touched up front bumper
Fitted dump valve
Fitted battery
Made engine water tight, ready for coolan on turn over
Relocated header tank to next to headlight
Ordered carbon for control panel
Ordered 6mm ID vaccum hose for a few places on engine
Fabricated a bracket for throttle cable
Looked into choosing a filter
Fitted centre section of exhaust
Modified the bonnet latch bracket to fit with FMIC
Fitted bonnet latch
heres a few pics of progress:
almost at the point to tick engine over and get all air locks out the system ect, then its just wiring and DONE! :wacko:
altho done is still a mile off because the answer to wiring is also the same!
looks wikid mate! jw did you make the throttle cable bracket because there was slack i the pedal??? i have this problem..
yeah was slack as, Na one made it tighter, but was way to low, sat below the fuel rail then cable had to bend back up to the throttle body so wouldnt have worked. this one does jobs spot on, no play at all. and when pedal is down to the floor, the throttle body wont turn round anymore by hand under the engine bay. problem solved!
@ idrees, i used a wired brush attatchment for a drill, then painted it in VHT silver paint using a half inch brush, looks alrite dunt it!
