russ78 Posted February 14, 2015 Posted February 14, 2015 (edited) CT12A - Starlet EP71 TurboCT12B - Supra Twin Turbobit of useless info for u colin lolor you have some very rare ct12 hybrids like my old one Edited February 14, 2015 by russ78 Quote
5e colin Posted February 14, 2015 Author Posted February 14, 2015 thanks guys no russ never useless :) now i can go on a search for the oil feeds for them on my ct9s should be strait bolt on then Quote
russ78 Posted February 14, 2015 Posted February 14, 2015 (edited) all ct9 lines should be fine as housing is almost the same just slightly larger side by side comparison few other pics might help [url=http://s1066.photobucket.com/user/russyb/media/2013-01-12171937_zps113a6dd6.jpg.html] Edited February 16, 2015 by russ78 Quote
karl. Posted February 14, 2015 Posted February 14, 2015 did yes its strait fit so link is good karl Sounds good, do you think it would be fit for 300bhp? Quote
5e colin Posted February 14, 2015 Author Posted February 14, 2015 would not know mate just try it there only 150 euros !!!! 250 i think no problem attal nice heave pedal so good clamping force for sure will be a while before i am doing 300 so cant comment yet sorry Quote
5e colin Posted February 16, 2015 Author Posted February 16, 2015 havent bean able to continue on my lil project for the last 4 days :( but anyways got 1 hour spare today so finished of the flange 50mm strait tru on the left for between mani and 1st ct9 then on the right 42mm because the internal diamoter is 44mm gives me more chance to weld on it before warp !! next up is the ct9 outlet flange 1s thats made i can weld them 2gether Quote
5e colin Posted February 17, 2015 Author Posted February 17, 2015 finished the ct9 flange today fits perfect perfect alignment al i have to do now is weld it up :) Quote
5e colin Posted February 17, 2015 Author Posted February 17, 2015 so taked it together and gave is a few smal welds ( going to weld it in 3 stages ) to see how it will look also beeing used to push with the mig i am al over the shop pulling with the stick going of line so it will be mig for the rest :) i wish it was done already want to feel a bit of boooooost again :) Quote
Whitenoize Posted February 17, 2015 Posted February 17, 2015 I can't wait to see this done should be awesome if it all works Quote
5e colin Posted February 17, 2015 Author Posted February 17, 2015 me to atleast it be a stock ct9 just hoping the 2nd ct9 packs a good punch of extra torque Quote
5e colin Posted March 2, 2015 Author Posted March 2, 2015 so didnt do fek al sinds the 17th ( but ) soooo finally got my BOC account sorted and forked out for some argoshield 2 liter bottle and a swp regulator , i set the airflow to 10l as i was told to for ms , also there only ( 18e ) refills :) so set up the mig an this is where my setting is best what do you guys think recomend dont mind the crap on the front thats when i was checking amps and wire speed also the brown stuff is that normal ??? this is after wire brush looks ok/good to me but i am just an amature welder so dont really know what to look AT Quote
Chops Posted March 2, 2015 Posted March 2, 2015 Turn your heat up a little, or turn your feed down depending on how thick the metal is, your looking for less bulbous flatter sides to your runs. The hole in one end run is porosity, thats no good at all, but all in all theyre not the end of the world. The brown stuff is normal,just brush it off! Quote
5e colin Posted March 2, 2015 Author Posted March 2, 2015 cheers chops its a rhyas 135A ( smal yoke ) my wire feed is at nr 8 ( out of 10 ) and power is on 5 ( out of 6 ) al the material i weld is 3 to 4mm thick pipe Quote
Chops Posted March 2, 2015 Posted March 2, 2015 Id turn the heat up, im not the big welder though i showed it to my coded colleage and asked him. Your set looks pretty basic, most i come across haved the feed rate in m/s and the heat in amps. Obvious suggestion i know but you may just have to look up what good welds look like and play with your sets settings till you can do runs that look like them! Quote
5e colin Posted March 2, 2015 Author Posted March 2, 2015 ha ya basic it is , its the cheapest gas/mig on the market ha ha , had another play a while ago i turned it to 6 and slowed the wire down a very smal bit welds a lot better already with the help from my neighbour , he checked/ messed around with the wire spool and guide motor etc etc, wire is coming out a lot smoother to now !! lesson learned Quote
Ollieh17 Posted March 2, 2015 Posted March 2, 2015 Ive started dabbling with a mig welder. The wire feed on it was absolute shit. Bought a metal liner for the wire and it improved it no end over the plastic sleeve Quote
5e colin Posted March 2, 2015 Author Posted March 2, 2015 could you link me for the liner ollie , anything to improve i wonder if a euro torch could be fitted ?? there great to weld with compared to this Quote
Ollieh17 Posted March 2, 2015 Posted March 2, 2015 this is similar to what i bought https://www.machinemart.co.uk/shop/product/details/clarke-2-7m-metal-wire-liner?da=1&TC=SRC-welding%20liner Quote
5e colin Posted March 4, 2015 Author Posted March 4, 2015 cheers amigo i welded it up fully and filled it up with water i only have 1 leak very tiny ( improving indeed ) going to drill it out tomoro and spot weld it up then continue the cleaning up of it to get it nice and smooth also a first for me i didnt warp it ha ha Quote
Chops Posted March 4, 2015 Posted March 4, 2015 When you weld two things of different thicknesses, you should try to aim slightly off the corner onto the thicker metal, 'pushing' the weld into the corner. this should help you not blow through the thinner metal. looks pretty good for a new welder mate, welding is something that takes a lot of practice to get good at, get some scrap bits to weld together if you can! Quote
5e colin Posted March 4, 2015 Author Posted March 4, 2015 cheers chops im able to do flat welding pretty good from back in the day with the stick welder on the gates we made but now those pipes is another story altogether i keep forgetting the length and angle . i start a weld pulling and up pushing the other end , really annoying habit ther that i picked up now mist get rid of it and keep it 1 motion i still have loads of gas left 3/4 bottle to, so will practice the pipes indeed there tricky for me Quote
5e colin Posted March 10, 2015 Author Posted March 10, 2015 my welding is getting better more fluent and beeds look better ( BUT ) when i come in very tight spots im still bodging it fecker would love some tips on tight spots ha ha fabricated this a few days ago :) ( only exhaust extension left ) waiting on gaskets and a few T pieces so i can instal this fucker think im going to make a ct9 mani to Quote
Chops Posted March 10, 2015 Posted March 10, 2015 Thats a mad old bit of engineering there, its going to be a nightmare to plumb in the whole lot all over the place! in regards to the welding in tight spaces, all you can really do is plan your assembly very carefully if using mig, or learn to weld stick as you can get it into much tighter spaces (its pretty cheap too)! sometimes, you need to cut things off of a job, or cut the whole job in half, to access an area you need to weld then join the two back up, its very annoying when your working to time constraints! Quote
5e colin Posted March 10, 2015 Author Posted March 10, 2015 pluming is easy few t pieces for now if al is wel upgrade to braided lines for safety just want it up and running for now !!! mad men are geniuses ha ha Quote
5e colin Posted March 12, 2015 Author Posted March 12, 2015 well my kit all clears in the bay but my lovly black boost feed doesnt clear the slam panel !!! fuck fuck fuck going to have to bend my panel a tat !!! Quote
