Whats your plans for your money pits over the winter months?
working on mine today, been busy fitting new central heating into the house, so not touched it for a while.
so i,
fitted the exhaust cam after stripping a thread for a cam cap
timing belts back on,
sumps nearly ready for re-sealing. (hate this job, get covered in oil, drips of oil going down your sleeve and lying on my back for too long makes me feel shit, lol)
just the brakes to clean and then finish fitting silicone hoses and fit a boost controller :D
Get the car runnin get the turno on it with oem exhaust and then get all brake new disks, brake lines and calliopes with pass from Toyota nd hopefully I'll get my respray aswell
Body work after finding some dick drove into me. Fitting my wepr manifold remap new injectors and more boost. push the stock lump a little more and a general tidy up.
yeah, i seen that, thats a shitter. just keep an eye out for a blue motor with white paint on it, then cave its windows in, lol.
cant go wrong with wepr stuff. :D
My actual plans are.
Test drive the daily's new engine and box setup, fix any problems that may arise.
New suspension and brakes...
As for the starlet?
Gut the wiring from the 2 doors I've got here for the starlet ready for fitting my wiring too then Change them over, also swap rub strips over.
Fit trackrods inner and outer.
Replace ball joints
check for loose shit/find source of my knocking from osf then get tracking done.
change seats.
Fix exhaust rattle.
fix high cold idle
Order and change thermostat
make brackets,then fit and wire MR-S PS pump + get lines made.
Source ae111 bzr osf outer cv joint.
Source a ae111 cat.
remap on emb?
sumps on, centre consul is trimmed for boost controller dizzy fitted, oil return pipe fitted tonight.
just, crank pulley, alternator belt, 2 heater pipes, antifreeze, and 3 discs to clean.
get some more miles on it then in for a map
Like any other GT owner I have a huge list.
Get a running engine
New clutch
Poly mounts
Buy all fresh lines gaskets for turbo
Repair intercooler pipework
New earths
New battery
Civic rad
Wire in boost gauge and water gauge.
Bumper support bar
New headlight alignment adjusters
Brake lines all round
Calipers rebuilt
Handbrake cable
Discs and pads all round
Finished with all fresh fuilds
All needs to be done by the end of Feb.
I have a list of mods I wanna fit also but need to get her running first.
Poly bush and modify rear beam
Fit anti lift kit
Powder coating
Under seal car.
Fit new front top mount bearings.
Wheel refurbs
New semi slicks
All new fluids
Geo
Trackday
Nurburgring
Season of toyota sprint series
Edited by abbott
Trying to get mine ready to come on the road soon!
Fit Livesports spoiler
Fit JAM bonnet scoop
Fit new exhaust
Order number plates
Bleed brakes all the way round
Wire the tailgate up
Check oil leak
Find battery clamp
Tracking
Couple new tyres
Then I think she's ready for MOT lol!
Aamir
Fitting oem wind deflectors and decide if i am going to keep it.
John
i am also thinking the same with mine, do i run it next year and sell to fund other projects?? wanting either the 100e or escort on the road so i can drive them straight sideways, ;)
