Pikey009 Posted November 12, 2015 Author Share Posted November 12, 2015 Lifts the front end nicely and not too in your face Quote Link to post Share on other sites
Dale SR Posted November 12, 2015 Share Posted November 12, 2015 SR looks great headlights are a nice touch Quote Link to post Share on other sites
Pikey009 Posted November 14, 2015 Author Share Posted November 14, 2015 Drove it 180 miles to my parents yesterday and didn't miss a beat just hope it keeps being as reliable. I've been thinking about the wheel refurb and was considering a darker grey but to be honest the car is so original I think I'll get them done in bright silver again By the way, to remove the PCV do I need to remove the rocker? There's nothing wrong with it that I know of but it is a little damp around that area and I know they're very important so I was thinking of changing it Quote Link to post Share on other sites
burty Posted November 14, 2015 Share Posted November 14, 2015 Love this car what else can you get that's rare, turns heads, different and reliable for just over a grand keep up the good work Quote Link to post Share on other sites
Pikey009 Posted November 14, 2015 Author Share Posted November 14, 2015 Exactly mate thanks very much. Hopefully the whole reliable thing keeps happening! Quote Link to post Share on other sites
Pikey009 Posted November 16, 2015 Author Share Posted November 16, 2015 Quote Link to post Share on other sites
Pikey009 Posted November 16, 2015 Author Share Posted November 16, 2015 The rear seats after I've had the carpet cleaner on them as they had some dodgy stains when they arrived. For anyone who's fabric seats need a clean- cant recommend using a carpet cleaner high enough. The one I used was a vax agility Should've done a before and after pic I guess Quote Link to post Share on other sites
Cammy R Posted November 17, 2015 Share Posted November 17, 2015 Nice Sr lad! Be careful with the rear 98 spec seats as they are mounted differently in the Glanzas from the n/a's and 96 specs i believe, so the bolts just under the seats don't go through the lashing eye bit on the base of the seat as i found out! Quote Link to post Share on other sites
morgey Posted November 17, 2015 Share Posted November 17, 2015 The 98 spec seat base have plastic clips that push into the floor and the seat clips into them. The back is the same as uk Quote Link to post Share on other sites
Pikey009 Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) So I should be ok then? I'll be having a go tonight thanks for the heads up Edited November 17, 2015 by Pikey009 Quote Link to post Share on other sites
Cammy R Posted November 17, 2015 Share Posted November 17, 2015 So I should be ok then? I'll be having a go tonight thanks for the heads up I'd go with what Morgey says as i only had a bash at it and i never reralised that it clips in like he says Quote Link to post Share on other sites
morgey Posted November 17, 2015 Share Posted November 17, 2015 Youll see the loops that stick down. If you look under the rear seat of yours you'll see the 4 rectangular holes that the clips go into. Quote Link to post Share on other sites
Pikey009 Posted November 17, 2015 Author Share Posted November 17, 2015 Well they're swapped- the foam bench is in but not massively secure. Think I'll cut the two loops off my old seats and weld them on to the new ones next week when we are doing the from seats. Quote Link to post Share on other sites
Pikey009 Posted November 17, 2015 Author Share Posted November 17, 2015 Made a start on the engine bay but it's going to take some work. I want to get the rocker cover painted- are the 4efte's rockers the same as NA's? Refurbed my heat shield tonight:Will be doing all the little brackets soon and renewing all the nuts and bolts Quote Link to post Share on other sites
SOG33K Posted November 18, 2015 Share Posted November 18, 2015 the heat shield came up a treat, will freshen up the bay heaps. Quote Link to post Share on other sites
Pikey009 Posted November 18, 2015 Author Share Posted November 18, 2015 Thanks I'm pretty happy with it but the rest of the bay now let's it down ha ha Quote Link to post Share on other sites
morgey Posted November 18, 2015 Share Posted November 18, 2015 Turbo covers have an extra breather Quote Link to post Share on other sites
Rich-k Posted November 18, 2015 Share Posted November 18, 2015 Sheild is mint! Think the rockers are different Quote Link to post Share on other sites
Westley Posted November 18, 2015 Share Posted November 18, 2015 Once everything is cleaned up and painted the bay will look spot on Quote Link to post Share on other sites
Pikey009 Posted November 18, 2015 Author Share Posted November 18, 2015 Ah thanks, hopefully it's going to take a while as the plan is to get a corolla inlet mani and refurb it. I'll get the rocker done professionaly i think. Would i be ok to run the other rocker on mine with a catch can? just i'll end up going down that route when i turbo it later in life. The 98 spec front seats arrived today from Jack they're from my old ep95 so it's a nice touch. He's properly sorted me out with them and genuinely nice guy. The seat frames should be getting the chop next week so i'll grab some pictures of that- hopefully all goes well! Quote Link to post Share on other sites
Pikey009 Posted November 19, 2015 Author Share Posted November 19, 2015 Tonight I added an aluminium dial surround. Might not be to everyone's taste but I just wanted to freshen up that area a bit and didn't want to go down the carbon route. Got the surround from eBay which came from Germany: http://m.ebay.co.uk/itm/Tachoblende-Silber-Tacho-Toyota-Paseo-Starlet-Blende-/190282944623?nav=SEARCH Came in three days and the quality of it is fantastic. Quote Link to post Share on other sites
Pikey009 Posted November 19, 2015 Author Share Posted November 19, 2015 After that, clean your clear cover as the finger prints will drive you mad otherwise. Refit everything and enjoy I appreciate this might look a bit anal and over kill but the surround isn't what I'd call 'cheap' so that extra 10mins of patients will pay off and give you the look you want Quote Link to post Share on other sites
Pikey009 Posted November 21, 2015 Author Share Posted November 21, 2015 Gave it a clean today Quote Link to post Share on other sites
Walker96 Posted November 21, 2015 Share Posted November 21, 2015 Looks so clean this mate!! Liking the dial plate as well looks smart:) Quote Link to post Share on other sites
Pikey009 Posted November 21, 2015 Author Share Posted November 21, 2015 Thanks buddy Quote Link to post Share on other sites
