AFM's on 255lph pump at idle
Yes, stock fpr
Not driven it yet
Have AEM wideband, no need to calibrate as far as i am aware.
Bit of a long shot but would the tank vent make any difference? Have noticed the last few times I've filled up a lot of air either escapes or enters.
Ran it for about an hour yesterday stationary after changing pump and this morning same thing...
Ok, quick update after a few hours work today. Have fitted a sard fpr and adjusted it to 2.3 bar and its still overfuelling loads so it seems that its definitely something demanding more fuel be it a sensor or ecu.
So next thing i think is change out o2 sensor as this would seem the most likely culprit.
Also to check sensor wiring am i right in thinking that i can test continuity between ecu pin and sensor wire plug? Anyone know what pin it is?
Have the same issue with my 255 pump fitted, started running very rich after, also changed the O2 sensor with didn't change anything.
This was also before I fitted the p+p ecu
