Content Count
657 -
About T-dog
Rank
Boosting a Starlet
- Birthday 07/08/1993
AIM
honda-repsol@hotmail.co.uk
Isle Of Wight
8692 profile views
Both sold . Thanks
Two an8 rocker covers for sale , one red and one white . A fresh painted AN8 Cam Covers in bright red and white they have been vapour degreased in Perchlorethylene to remove dirt and carbon build up and etch primed then painted using high quality durable paint. Β£100 for the red one and Β£80 for the white one ( the white one has a few marks in the paint but still looks good) Β£10 postage.Thanks Toby
Yeah I fitted one of the first kits , was a great upgrade and straight fit. Anymore info pm me ππΌ
The wires you are after are - BLACK/RED = POWER BROWN/WHITE = GROUND YELLOW/RED = TPS SIGNAL
Yeah that looks like the alternator plug and power cable . Itβs will be around there have you anymore plugs ? It could well have been cut off ?
Glanza steering wheel airbag resistor value
T-dog replied to Nafeez2125's topic in MOT & Maintenance
Good find . Always good to keep the light working without taking the bulb out etc ππΌ -
Most people these days just blank them off with a made bit of a metal and original gasket and then just loop the coolant hoses . Then just adjust the idle through the screw on top of the throttle body . I have done it on few of these cars now with no change to cold starting . If you donβt wanna do this have you taken it off and given it a good clean etc ? . Hope this helps ππΌ
I use red stuff or ds2500 both amazing for fast road and light track use ππΌ
Startermotor replacement 4efte facelift glanza
T-dog replied to RoyalDutchie's topic in Drivetrain & Transmission
I have fitted na starter motors before on a couple of glanza no problem . Slightly smaller in ah but still work fine . Also fitted a auto one year back just had to nut and bolt one of the holes . Lots of options if needed mate ππΌ -
Try unplugging the emanage and see if will start up on stock ecu . Worth a try just then one more thing to role out ππΌ
Is it on stock ecu or aftermarket ?
All earths on the loom put back on the engine ? Like idle control valve earth point , bulkhead near igniter , both earths on the gearbox and mount , other side on the mount to body , both front wing earths. Itβs just a case of back tracking mate if it was running before It must be something simple . What did you take apart to sort the coolant leak ? ππΌ
