5T4R7ET N/A
  • Content Count
    2028
About 5T4R7ET N/A
  • Rank
    Starlet Specialist
    Hemel
7468 profile views
  1. If built properly its good, if not then its new engine time.
  2. I have seen this happen with other sellers wanting very high prices. I saw a item i wanted but it was double the price i would expect, so i offered reasonable offer which was a little above what they sell for, explaining other similar items. He was like no way, im not going below £xxx. I was thinking fine if you can sell for more then go for it. then two weeks later he is reduces it for EXACTLY what i offered. Im not buying it out of principal now. 😂
  3. Try just to earth the horn button. The horn Button should not need a live feed as gets power from the relay.
  4. The horn on steering wheels normally just work when the earthed. make sure the earth connection is good on steering column The horn itself has a power supply and bracket is earthed to the body of the car. hope that helps
  5. I think the only reason the noise is going away when you turn the steering is because the engine rpm is changing. The engine sounds like the bearings are worn. This noise will be louder when engine is warm whilst at idle. Oil pressure lower so you can hear it more. what did the mechanic replace? Because it sounds like you have same problem.
  6. The rpm limit on a 4EFTE is 7200rpm. Thats probably the issue. Your missing 700rpm, so that would add to the top speed
  7. No it will make that without the piggyback. with the piggy back you should make 170-200 with the right supporting mods. Depends again on what boost you run. i would say 0.8 or 1 bar being the norm.
  8. First of all you cant remap the standard ecu. You will have to get at least piggyback to if your thinking that route standard ecu with the right mods like front mount intercooler, decat and good condition turbo should make around 150-170bhp. So many variable like engine condition will make a difference as these engine are getting 20+ years old now.
  9. From memory i think the Bolt head is 14mm.
  10. I needed a new intercooler as my old one had weathered pretty bad. The fins were turning in white aluminium powder plus i wanted to change the setup a little. I measured up and this is the biggest i can fit with my setup. The hotside will remain very short and the cold side will be a little shorter inside the chassis leg as before. This is only 5mm thicker than previous intercooler so should fit ok. I hope 😅 back front top Will be mocking up soon to see if any mods will be needed to make it fit. I want to retain the crash bar.
  11. Yeah its a Silver crown saloon. Cant believe how smooth they are. My one is bone stock auto at the moment. Thats a another project to my list. 1. starlet 2. crown (daily) 3. Mk1 Leon cupra R (wifes car) They are all turbo petrol cars 😎 When i start working on crown probably put another build thread on here. I plan only to change wheels on exterior keep a nice plain look. Want to make a sleeper
  12. Thanks for reply. 👍 I will try and make one like yourself.
  13. I had similar issue with ignitor, they are earthed through the bracket and mine was loose. Its always the simple things 😅
  14. On first start up the standard ecu runs rich until warmed up. Then it will lean out. I assume you have a wideband AFR gauge to monitor this?
