I can overlay a dyno graph of any starlet onto it so you could see the comparison. Ah, do you have an EP3 or EK9? I'll have plenty of graphs of those I could overlay from stock to 485hp. N/a, S/c or Turbo.
Your criticising things what either don't matter or don't understand. If I made the car do 2 bar at 7000rpm's it wouldn't make a single HP more. The head/cam intake are absolutely maxed. Look at where the car makes peak power. You will have the exact same problem in a few weeks i'm sure. Sock's has a ported head also. The AVCR is the best boost controller IMO, the point is I didn't want to make any more boost higher in the RPM's it didn't result in any more power. It was setup on the dyno.
It actually spools really well, it makes more power than a standard starlet (at peak power) at 3800rpm's. Also remember a bigger turbo at a lower level of boost will still flow more air. I.e. This turbo at 0.6-0.7 bar will make more power than a TD04 at 1 bar. Video of spool: [media]http://www.youtube.com/watch?v=pA2wH4XNtmo
The PFC isn't a great ECU by modern standards to be honest. It lacks features and isn't the most flexible. We already found limits on Sock's car using a power FC. The problem with most plug and play standalones is they are connected to a 20 year old loom and sensors. We are currently working on a system what will complete remove the standard wiring loom sensors and obviously ECU. This will obviously cost more than most systems out there, but will allow for a much greater control and you can remove unsightly things like the distributer etc.
