Rob H@RCH Engineering
    1683
  1. And could do with some picks with a tape/ ruler showing how big the gaps are Im thinking my idea may work!
  2. Have you got room for a filter to go in the front behined the bumper?
  3. Well it's nearly 12 so thats only 6h late lol
  4. have you got any better picks of the room you have to offer? I may have a suggestion!
  5. That could work but it would be quite restrictive as you only have a tiny surface area compaired to the actual filter, it would sure filter better than mesh tho!
  6. I run a BOV and a air filter but the bov has quite a hard spring in it. mine dose sound a bit odd tho as im running fully sequential ignition and injection https://youtu.be/24Np1b4kRyA https://youtu.be/t63aGpthyKw
  7. Its now taxed!! And ready to go see Will at RDT.tv for setting up! Carnt wait!!
  8. Cheers lads! Colin I will prob wont run a gauge as the fuel pressure is monitored by the ECU, I used the snap-on thest gauge tho to set the base pressure. Video to follow soon! Its just uploading to YouTube! Here it is! https://youtu.be/X5eVcJ9HXA4
  9. Thanks mate! This is my youtube https://www.youtube.com/user/RobSRturbo/videos not everything on it can be watched tho lol some I will have to send links to!
  10. Got most of it done done! Just need to swap the TPS plug and pin in the injectors and speed sensor to the ecu and it should be good to go! [url=http://s87.photobucket.com/user/turbosr_2006/media/toylet/CB65CE3D-AD1B-47F7-A7FD-7206BE62F681_zpsymkeawxw.jpg.html][/url
  11. Well I got the fuel rails fitted today just need the finish the fuel piping off now and sort the boost pipe and wiring then mapping! Im going to remount the reg to the engine so theres less stress on the pipes and fixings with engine movement. I did not weld the fittings on the rails my welding int upto that job yet lol
  12. Running it off the wide band is fine but pussy footing it every where is not what I'd recommend for the running in, it needs to see some boost and some engine load, or you may as well leave it ticking over on the drive for a day, id get the ecu fitted and it run in on the dyno befor driving it around pussy footing it.
  13. Running ritch on a fresh bulit engine is not a good idea! Bore wash could be a major issue
