  • Replies 1.7k
  • Created
  • Last Reply
Top Posters In This Topic
Cheers matey :thumbsup:
Should be cracking right on with this this weekend hoping to have everything ready to drop back in next weekend time is running up!!!
1.2 mate, keeps the stock compression ratio then, 1.4 will lower it slightly, OK if your going for high boost but will make it more laggy off boost
Just a quick update.
ABS is removed as well as the charcoal canister and the rest of the air con gubbins. The ABS loom has mostly been removed from the loom also just so it looks a bit neater.
Then out came the degreaser and all the underneath, inner arches and engine bay has been steam cleaned, what a transformation!! Looks 10 times better and we havent even finished yet!
Gearbox has also been thoroughly cleaned and again looks alot better so far.
Turbo kit is almost assembled and I couldnt help but fit it to the old engine, the words of my old man, "thats a piece of kit" ;)
Anyways I'll have to tease you and leave the pics until tomorrow where hopefully things start going back together :o
Here we go :p
Manky cluttered engine bay at the start of the morning
Charcoal canister and other rubbish
Aircon pipes
ABS unit
and removed
Charcoal canister and air con wiring loom to join it
Aircon pipes gone
Manky gearbox
Clean gearbox
Engine bay in the middle of being degreased
Looking cleaner
Dirty wheel arch
The other side steam cleaned
All clean
Shagged engine mount, completely fell apart
Gearbox mount aint much better
Clean with most of the shit removed still needs tidying up though
And the end of today :D
So heopfully when my engine mounts turn up it can go back in the car B)
Thanks for looking
awesome updates dude, cant wait to see this on the road, when its not attatched to the back of a jeep lmao
x2 :p
Engine/turbo kit looks gorgeous! When you hoping to have it running and on the road?
Cheers guys :p
Hopefully running next weekend then finish the rest of the jobs on the interior, brakes and suspension so in a month it should be going for a MOT :D
what parts on the inlet did you have to block off ? i wna strip all my aircon parts out but im still scared to haha , when striping it back from the loom did anything hve to be cut or was it just undo the tape and pull it out ?
