pick1 Posted March 26, 2012 Posted March 26, 2012 Looks sound to me mate the easier the air can flow surely the better it will be but just my opinion 😜 Quote
Flaminsam Posted April 11, 2012 Author Posted April 11, 2012 Small update, Went down to my lock up last night to bleed up fuel system. After finding about four leaks I left the engine turning over for too long and it actually fired up! Needless to say with it not having an oil feed for the turbo on yet it pissed oil out all over! I'll update when I get in with pics, finally got my boost gague and coolant temp gague mounted. Left to do list,Front brake discs, power steering belt, oil feed for turbo, swap tyres onto rims and finish off a few small items inside. Quote
*Zoe* Posted April 11, 2012 Posted April 11, 2012 Exciting stuff!end is deffinataly in sight or should i say begining Quote
Socks Posted April 11, 2012 Posted April 11, 2012 Dont start it and run it anymore without a turbo oil feed Sam! Low Oil Pressure is not safe!Get one off Race-Tech will be with you before the end of the week im sure! Quote
Taggy Posted April 11, 2012 Posted April 11, 2012 Wow is all i can say, cant believe you have managed to get this thing back on the road, looking at that first pic you would have thought it was ripe for the scrap factory!Good effort Quote
funny onion Posted April 11, 2012 Posted April 11, 2012 still might be ripe for scrapland! haha not had it actually running yet, bottom end could be buggered or anything. we shall see. if the engine dies the gearbox is going on mine, i've decided haha. Quote
Flaminsam Posted April 11, 2012 Author Posted April 11, 2012 Thanks for the comments guys and girls. Don't worry socks it got turned straight off as soon as I heared it fire up. I've come across lack of oil pressure many times before Yea taggy the shell was all I had, I've pretty much built it from the shell up. Not bad considering I only got the shell Jan/Feb time. We will see charl. The gearbox could be shafted yet Quote
Flaminsam Posted April 20, 2012 Author Posted April 20, 2012 small update folks. i went to pirtek today and had an oil feed made up. £30 for two banjo's (10mm and 14mm) and 500mm of stainless braided ptfe pipe. it can withstand pressures of up to 200bar and temperatures of upto 450 degrees. so should work well.any who i went to the lock up after going and getting a pas belt and fitted the oil feed. after using the vitara to slave from the shedlet fired up. slightly tappy to begin with but quietend off after about 10secs. oil light went off straight away and the alternator was charging. only now need a bottom hose which should be here tomorrow and fill the gearbox.all im going to say is .................. EXCITED! il get some pics and a vid up when i can. Quote
Flaminsam Posted April 21, 2012 Author Posted April 21, 2012 All in good time john. Considering I've only had the car for 3 months today I think its gone rather well. Quote
ro55ifumi Posted April 21, 2012 Posted April 21, 2012 It has mate and is coming along really well SamJohn Quote
aaddzz123 Posted April 21, 2012 Posted April 21, 2012 ! I'm glad she runs matey! Really looking forward to seeing it outside of the unit ha Quote
pick1 Posted April 23, 2012 Posted April 23, 2012 your so close now mate bet your twitching great progress considering what it was when u first brought it Quote
Flaminsam Posted April 29, 2012 Author Posted April 29, 2012 hey all sorry for the long delay in an update on the shedlet. Firstly i would like to say a massive thanku to charl (funny onion) thanks for being there through this build and for putting up with me when i had many nights down the lock up. also thank you for buying me some of the key items have needed to get the shedlet running. well if some of you have me on face tube then you will already know that the shedlet lives and has been for a drive down a private road to check gears and engine etc. i let charl have the first drive as she has helped me out alot. bear in mind that the project is still ongoing and this will not be the end! any who like i was saying charl had the first drive. and her words were ''ditch finder''. turns out the tracking on the shedlet is way out. its toeing out by a good 40-50mm, some one who had the shell was clearly having a laugh. il have to sort that asap. so with the tracking being a country mile out and brakes needing some more bleeding we retired back to the lock up. anyway less of the reading, im sure you all want to see some pics. here is how far the tracking is. bear in mind that the steering wheel is straight and i have not moved the car for the two pics. here is the turbo oil feed pipe i had made up. a friendly service from pirtek in hull and i would recommend them to any one. i also got the washer bottle and battery secure in the boot. i then used conduit to cover the unsightly wiring. looks tidy i also had a new sensor housing made up by my friend at zcars. this sensor is for the hks coolant temp gague on the dash. i even attached a old pipercross air filter for now until i create something better.i also got my 60mm hks boost gague plumbed in. heres charl bout to take the maiden voyage.hopefully with a few more parts sorted the shedlet will be going for mot hopefully this week. then there will be no stopping me. Quote
aaddzz123 Posted April 29, 2012 Posted April 29, 2012 I like this about this much {}Big loves.Adam. Quote
funny onion Posted April 29, 2012 Posted April 29, 2012 The whole experience was terrifying. Especially when you semi panicked which made me panic lol. All in all, it will be amazing when straight lines and corners are achievable hahaha. Quote
Flaminsam Posted April 29, 2012 Author Posted April 29, 2012 all in good time charl. but for now its a good job it drives and the engine sounds sweet also. Quote
Socks Posted April 30, 2012 Posted April 30, 2012 Japfest in less then 2 weeks! u better be there Sam! Quote
Flaminsam Posted April 30, 2012 Author Posted April 30, 2012 We will see Matt. Hopefully have it mot'd this week. But it all depends on if the final few parts arrive in time.oh does anyone know what the bulb type is for the rear lights. I need a stop and tail lamp. Quote
Starbuck Posted April 30, 2012 Posted April 30, 2012 Nice updates. Great FB write up as well. Lol Quote
Johnboy GT Posted April 30, 2012 Posted April 30, 2012 Nice project mate! Come along way! Can i ask what you used and how you painted the inside rear of her? As im goin to be doin the same! John Quote
