  • Replies 116
Posted Images
  • 1 year later...
Well. Its been nearly two years since this thread has been updated.... SO! Here goes!
The car has been parked up for a year while ive been busy with other projects and various other duties.
I decided I wanted to get on track more, this thing was laying around so decided, sod it. Track Car.
The thing was already reasonably spec'd, few tweaks here and there and she would be ready!
So gave the thing a bath.
post-2707-0-37950100-1496918935_thumb.jp
The current spec list was:
Power Getter Exhaust
Decat Pipe
HKS Actuator 0.7bar
HKS Mushroom Filter
50mm Springs & Standard Shocks
FMIC Kit
Powerflex Rear Gearbox Mount
Short Shifter
Recaro SR3 on ZEP Rail
OZ Superleggra Wheels & Parada's
OEM LSD Box
So first things first!
I got the car weighed at the local weigh bridge.
Accurate to within 5kg.
post-2707-0-00405700-1496919093_thumb.jp
With all the interior, ICE, seats. etc I was happy with that!
So weight saving started!
post-2707-0-19111500-1496919178_thumb.jp
post-2707-0-46145800-1496919187_thumb.jp
post-2707-0-01067500-1496919226_thumb.jp
Once stripped, noticed a water leak into the boot. Was coming from the rear lights....
post-2707-0-06649900-1496919335_thumb.jp
New Seals
post-2707-0-48430400-1496919350_thumb.jp
Then some sound deadening removal.
post-2707-0-88246800-1496919431_thumb.jp
Ill get this painted inside at some point!
Rear Wiper Gone:
post-2707-0-92487000-1496919524_thumb.jp
More Engine Bay Shite, including ancient alarm (I have immobilised the car in a different way)
post-2707-0-01827100-1496919575_thumb.jp
Fitted the other 2 Powerflex Polybushed mounts and some Magnecore HT Leads.
post-2707-0-98550000-1496919905_thumb.jp
post-2707-0-97536200-1496919930_thumb.jp
Did a full service and put some Castrol Edge Supercar 5w60 Oil in. Along with a fresh dizzy cap and rotor arm, Oil Filter, Fuel Filter. etc
A Low Black Sun Strip as the Seat is so low.... and I removed the sun visors.
Then fitted some 195/50/15 Federal 595RSR Tyres.
Then finally, a trip to see Nick & Mike @ TD to get this fitted:
post-2707-0-14157200-1496920028_thumb.jp
The car made 185.0bhp at 1bar.
Then it was time for Blyton Park again!
post-2707-0-80432200-1496920464_thumb.jp
post-2707-0-42485900-1496920314_thumb.jp
Got 2 very close mates who I do track time with who have Ep3's that are tweaked to a pretty high standard!
Had a great day, was a nice cool day. Had no troubles all day. It was very hard work to try and stay with the ep3, but considering money spent, certainly cant complain!
post-2707-0-66888700-1496920548_thumb.jp
post-2707-0-89721700-1496920553_thumb.jp
post-2707-0-52184700-1496920557_thumb.jp
The tyres were really really good! Very impressed!
post-2707-0-33283100-1496920609_thumb.jp
After this day, there were many things that came to light, where improvements needed to be made and mods needed to be fitted!
Updates Soon.
So, before the 3rd track day this year, the car needed some improvements!
First off being Brakes. The stock Toyota Brakes were great on track but after a day, they sounded dreadful, it had taken its toll! They wouldn't have done another....
post-2707-0-70744700-1497003811_thumb.jp
post-2707-0-52981400-1497003818_thumb.jp
The discs were fine and in good condition. but the pads not so much!
So thanks to Amjad....
post-2707-0-17186200-1497003883_thumb.jp
The noises went away and these things are shockingly shit when cold but when up to temp.... Jeez.
You can feel the back go light, more then enough power to lock the front wheels completely. Even on semi slicks up to temp too!
Then to try and close the distance to the civics, some suspension/setup work were needed!
So opted for Whiteline's Front Camber Bolts & Rear Anti Roll Bar.
Then had the whole thing setup to my preferences at a local KwikFit on a Tiger Laser Align.
post-2707-0-53435800-1497004305_thumb.jp
Opted for No Toe Angle and -2deg front camber.
These changes made a huge difference to the cars behaviour that is for sure.
post-2707-0-71979900-1497004316_thumb.jp
Then to keep an eye on things. Stack Oil Temp Gauge in a custom mounting plate...
post-2707-0-24807200-1497004494_thumb.jp
This would reveal an issue on the next track day where thanks to a heat spell of 30deg ambient. Oil temps were getting worrying!
Followed finally by a hypersport shifter (combined with an interior one too)
post-2707-0-88085900-1497004559_thumb.jp
Shifts are super short now!
Bit more weight saving:
post-2707-0-28874100-1497004667_thumb.jp
Cabin looking proper now.
post-2707-0-30212800-1497004690_thumb.jp
So it was time for the next track outing!
Car performed Great! Felt much more stable and really planted compared to before.
However, oil temps were a real issue. 4-5 laps of Blyton was seeing it soar to over 120deg at which time I was backing off and heading in. So lots of short sessions! Which was annoying!
The civics were much closer this time and the car was much more competitive...
Was struggling with understeer on the long sweeping left hander at Blyton. But on the brakes and in the slower corners the Starlet is far superior to the Ep3!
More setup and Changes needed tbh!
post-2707-0-55492100-1497004971_thumb.jp
post-2707-0-26710600-1497005015_thumb.jp
See some video footage here:
So.... again things to improve....
Oil Temps need lowering.
Oil Breather System.... Erm. It needs one....
Its going to need a bit more power on larger tracks to stay with those Pesky Ep3s! So maybe a TF035 at some point....
More to come folks
Love a good track car build! Two questions.....
1: where the glanza stand now? An update is needed
2: your wife/girlfriend must like you alot to deal with the starlet fever you have
James
  • 4 weeks later...
You can't knock those Honda's. That's one thing I noticed about the Starlets out on track. Every one I've seen needed to pit for a little breather, compare it to the EK9's or EF's which would be out all day like on the limiter....
Looks like a great day though.
Edited by Calum122
James
1, Update coming on that soon! Not enough time in the day!
2, She is very accommodating... :)
What you doing looks really good Matt, what is the spec of the EP3?
Cheers dude.
There both prepped by Area Motorsport.
Add 'joeburgess_94' and 'm15_kco@ on insta. You'll see!
Love the noise off it.. how'd you do that
Cheers dude. Pretty basic setup tbh, see the spec above in the thread.
Generally N/A cars dont struggle with temps as much as turbo'd cars.....
Anyhow.....
Got my Grex Oil Cooler fitted now!
post-2707-0-13157100-1499111931_thumb.jp
post-2707-0-81396600-1499111938_thumb.jp
Its certainly sorted out the oil temp issues. I cant get temps above 90c now hehe :)
At Cadwell on the 13th July. So we shall see how she does!
  • 2 months later...
Matt, how do you manage to run -2° of camber?
I've got the same setup as you..Shocks and springs with the whiteline camber bolts and I thought they could only adjust to -1.5° camber?
Marc.
  • 7 months later...
Marc.
Whiteline Camber Bolts dude. Swap them out to the other hole of the 2 in the strut/hub ;)
So!
I did several track days with the above setup last year.
Improving the car each time, in small ways.
Adding:
Cusco BMCS
Triple Core Civic Radiator (This one was important as temps on track are hard to manage)
Oil Breather System that can cope with added boost
Paddle Clutch again to cope with more boost#
My own civic rad brackets:
5acc55ca1db24_Photo06-10-2017074329.thum
All fitted up.
5acc56242f40c_Photo_06-10-2017_11_46_01.
Then started putting breather system together which was a complete DIY job that turned out great!
5acc565c1dc1a_Photo_14-10-2017_14_22_12.
Then I ended up getting this kit for £250! lol. Couldn't turn that down that's for sure.
5acc570e554db_Photo08-01-2018182233.jpg.
Sent the turbo off to good ole Liam to get rebuilt, with a Billet Wheel. Liam does a great job as always.
5acc57354ad0b_Photo_28-02-2018_11_37_28.
5acc573885b8f_Photo_28-02-2018_11_37_41.
5acc573e2e91b_Photo_28-02-2018_11_37_50.
Get it all fitted up:
5acc576d017bd_Photo_24-03-2018_17_23_35.
5acc5765e6dc4_Photo_24-03-2018_17_17_12.
Got an AVCR off a local for sale page on fb for £100! :D
5acc585c9c82b_Photo_25-03-2018_10_31_05.
Got it all finished:
5acc59422bfee_Photo_07-04-2018_09_56_11.
Then it was mapping time.
5acc5961cafd3_Photo_04-04-2018_15_36_35.
5acc596a07ce0_Photo_04-04-2018_17_05_34.
Made good power too!
5acc59b35c6d0_Photo_04-04-2018_16_44_39.
lol whoops. Sorry engine :D
Anyways, onto Blyton for a shakedown!
5acc59e627549_Photo_07-04-2018_12_54_24.
Car performed so well all day. The tyres on the front were fucked, this was there 5th track day. So i turned it down to 0.9bar, even then was spinning at this corner exit.
So much fun tho!
EN9I2686.thumb.jpg.ad86bca7b33a8e7884588
EN9I2941.thumb.jpg.2b924384214bfaf471e01
EN9I3958.thumb.jpg.4feb39c9fb946fea8f093
EN9I4426.thumb.jpg.75ce016686eefbabd33e0
The amount of people that came over and asked first of all wtf was under the hood but then said its hilarious to watch on track.
Mixture of the tripod thing and the noise it makes. It puts on a show haha!
5acc5bb5d5022_Photo_08-04-2018_16_53_32.
It was a great day, nice to see GlanzaMac too who popped in to say high! Slowly over the afternoon it got more and more moist until it eventually caught me out on the brakes and it span lol. I nearly held it but it was going round!
Then a video of the highlights with some good battles!
All good fun! Cadwell again next in May!
Lovely colour in them, 2 questions, how big is your fmic core ? Where did you get the wee plugs for the rear that where leaking ?
Cheers
Nice build socks.
how do you find the civic rad for coolant temps? I struggled with mine on track, but like you was also seeing over 120 degrees oil.
currently fitting an oil cooler so I'm hoping with 30 degrees or more pulled out of the oil should help the coolant. Also think my coolant was probably slightly too concentrated which would have led to poorer cooling.
  • 1 month later...
On 10/04/2018, 09:32:27, Calum122 said:
Fantastic stuff!
Car looks great.
Cheers Dude!
Cheers
Cheers man. Its just the usual Blitz size. Not overly big. etc
Toyota.
On 16/04/2018, 12:26:02, adzy said:
Nice build socks.
Cheers dude.
Coolant temps are fine now. On a hot ambient day on track cant get it over the thermostat temp (82c).
Oil Cooler wise, I can still get oil up to too hot, but its after much longer sessions, so maybe a bigger core at some point, but its not a concern right now!
On 16/04/2018, 13:15:11, wakeabby14 said:
Dont suppose you would swap your top mount kit for a ram horn kit from wepr ;) Wish i went top mount now gutted haha! £250 was a bargain for that kit.  Great GT!
The kits ok. Collector is a bit poor flow wise. Fitted perfectly tho, no complaints for what I paid for it!
So! Id been having an issue with the coolant slowly moving into the overflow bottle over time (2-3 track sessions) but then not moving back.
Having replaced the thermostat, rad cap, radiator. etc trying to sort it throughout the year. I decided to bite the bullet and do the head-gasket just to rule it out.
Also would give me an opportunity to see inside the engine to see what the score is!
So! Off came the head!
5b027455b034e_Photo19-04-2018122434.thum
It looks great inside, obv carbon built up which backs up the mileage.....
But the bores and head looked great! So gave her a scrub up!
5b0274a8548fa_Photo19-04-2018144939.thum
Thats better :)
Then re-assembled with a new Toyota Gasket and these:
5b0274c401519_Photo_17-04-2018_11_26_21.
All torqued down tight, and Cadwell Park around the corner. Time to see how we do on those Water Temps!
So! Onto Cadwell!
With new bigger tyres on the front, the old ones had done 5 track days :D
5b027643a0f2a_Photo_05-05-2018_10_15_14.
5b027646aa475_Photo_05-05-2018_10_39_05.
And new brakes, disks were warped big time after the late braking at Blyton last time, so new disks and inspect the pads....
5b0276735285d_Photo_05-05-2018_13_17_19.
5b02767f5bef6_Photo_05-05-2018_13_17_17.
Another day in them yet :p...... (which there was lol!)
So off we went to Cadwell, this with a good handful of mates. Think there was 4 EP3s, Dc2 & Mk5 Zetec S Fez too.
5b0276cdbce9e_Photo_10-05-2018_11_19_07.
My good friend Joe, (Red EP3 with black lip) again had some good fun on track with him as you'll see in the video....
Didnt go so well for the Fez tho!
5b0276d4ad124_Photo_10-05-2018_12_23_13.
He lost it through hall bends :s
Anyhoo, was a mega day! Car performed Amazing all day. Only used low boost again all day, it really was enough! Grip was so much better, altho a little scrubbage, I will get away with a slight arch roll! (on the front)
DSC_1974.thumb.JPG.65f23902739f9ce9f4b41
DSC_1947.thumb.JPG.517f0acd6addd28125a03
DSC_2650.thumb.JPG.38849ff5f037c5d96b110
DSC_2805.thumb.JPG.0fbbd1dc13edba6cad9b9
DSC_2851.thumb.JPG.557586efb52bb5aa33bd3
New Brake Pads and a few other little mods for the next one!
Enjoy the video. We were getting times down into the high 1:40s which is pretty respectable!
GoPro went flat towards the end of the day so most of this is late morning where we were still getting a feel for the track/grip levels again.
https://youtu.be/Jp0HVoMK_bM
How did you get on with the water temps and coolant being pushed into the overflow?
Mine did that, eventually it got so bad the car got hot and cause problems with the head and block.
Not at Blyton this coming Saturday any chance are you? Friend of mine is out and I'm in the area so was going to pop in and say hi.
