  1. Haha i was thinking the same! I recon polkadot
  2. Ahh fair enough
  3. Also whats the deal with the toyosports mani thats £830?? Lol
  4. Im being dumb i dont get the batman one? Lol
  5. He's got a very keen eye for stuff in the background etc like the one where hes put a fan in it because she looks windswept lol
  6. Were u chopped out dude?
  7. Everytime i see it i burst out laughing. I like the p.s i have the same makita drill as you lol
  8. Welcome along dude, see ryans already flooded you with info! Haha This place becomes a second home before you know it
  9. Would be good to have 2 side by side portraits one month. Or maybe the calendar cover?
  10. Ouch man that looked like it hurt any reason the air bag didnt go off?
  11. Thank you my man, i was going to check this anyway see if this is where the leak was so ill take a pic when its off
  12. Why when V spoilers are nearly the same?
  13. 1998 SR if that helps? Is there any differences that i can see visually without removing it?
  14. Awesome dude good to know! ill look into it and see if they're the same Cheers
  15. Edit need a new tank! Put simply i need Ep91 n/a fuel tank No pump etc Maybe the straps (best to have them if youve got them if they have a tendency to break on removal?) Most Be able to post or reasonable distance to collect from norwich Needs the round type fuel pump mounting, pictured here... So lemme know what you got Cheers morgey
  16. Mine was a c52 for 4A but the only difference is the bell housing so it would have been close to it. I think they seem quite light because they're fair compact and easy to lift.
  17. My old box weighted 32kgs with all the brackets etc still attached. I weighed it on a calibrated set of scales at work :/ Has he taken the cups out and drained the oil out? Also now youve got the diamentions most sites have a quote by size and weight form you can fill out to get quotes anyway
  18. Right one off turbo into larger outside feed on ebc. Center one to waste gate Smaller outside feed to inlet manifold That should be it
  19. Well either off of the turbo or the int piping. I would say replace that red int piping with the black hose going to it (pictured ^^) with your inlet manifold and go with that Also yours will differ depending if your wastegate is single or dual lined?
  20. Have you not got any other nipples on the int piping that you could feed it into?
  21. That 2nd pic is different as the wastegate has 2 ports on it :s
  22. From what i can gather by looking at them pics Center line to wastegate Smallest of the 3 to your inlet manifold Other side the larger outside one to somewhere on your intercooler piping (after turbo before the throttle body) The 4th port on the other side would be left open to atmosphere
  23. Im suprised that the fte uses the same as the n/a's you would have thought that they would be a different because its for turbo aplication. But i guess its not exacty a hi performance engine in stock form :/
  24. correct me if im wrong but isn't there an intercooler tucked away in there? looks far to close to the front to be a radiator :s
  25. Yea nice one mate be good if we did
