turbo Grant
    2479
  1. Proper happy with the wheels more so the rubber. It's actually fun going round corners now! Had a delivery at work today! Got it fitted as soon as I got home! ep71 S dials I think they are. Swapped a couple of wires round and every thing works a treat. Just need to put a new clock in some were, change an illumination bulb I missed and fit the speedo converter I've had sitting round waiting to be used
  2. Little update, changed the old steels out for some racing sparco crimsons. It's so much better to drive now! Need to make some drop link up of the GT anti roll bar that I put on and swap the suspension off the paseo
  3. I would laugh if its ok when you start it up
  4. Does the pipe have a lip on it or have you / been cut? You can put done dome screws in if its been cut
  5. I wouldn't have thought it would cause the idle to fluctuate. Do you have the filter/ damper in the map sensor pipe? And when the wax stat in the tb goes that usually give you a high and annoying idle. You got the temp sensor sorted? You could just be getting a bit of a lean missfire
  6. It is an idle control valve in the tb. That one on the end of the manifold people go on about does f all from experience.
  7. I'd stick one into my jam bonnet. You just use rtv instead of tiger seal
  8. Awesome.....get a GT!
  9. And the rear floor pan is totally diffent for axel mounts. You would need to make a whole new floor pan. Better off importing one for a couple of grand.
  10. hes fucking miles off stll! The small man chats shit
  11. I had some mono flex on my old GT. They are not for road use really. I suspect you will need to replace the front shocks at a cost of 800 probably. Cheaper to buy new suspention
  12. I want to fill your crack lol
  13. This has been cracking me up >http://youtu.be/SMHhy-mGndI
  14. You should wire air horn off another relay getting power from the battery.
  15. I'm just going to go as my self. Easy
  16. Wicked car that looks like my old TD fuel rail aha
  17. I had great joy doing my 70 clutch at home on a gravel drive. Got the bastard back in after some focking about. It's far easyer lifting them in above your head that's for sure.
  18. Always the case. The solution is staring you in the face
  19. You having problems with the trigger pick up?
  20. Dizzy doesn't have power going to it. They have vr sensors that creat there own voltage.
  21. You can bolt on all the parts but with out it being tunned you will never have any massive or benificial gains.
