Content Count
2479 -
I'm after some good ep82 sun visors. Not floppy ones with broken wires. And I need a read quarter interior trim. This is the pattern I'm after Let me know what you have!
Went up to Kent last weekend and picked up a 1987 ep70 off epsteve on here. It's sporting the power house 1e 12v engine. Picked it up with about 71500 miles on it. Clocked over the 72k on the way back from jf2 today. I've I've only got the one picture at the moment Done some bit to it like change the clutch, fit GT seats sort blowing exhaust. Mot and tax it. I've got loads of bits for this
You can use these fine. Past this item number into eBay 370846758679
Rotated ct9 set up I made a bracket like that for my kit. Loads better than facing up
Don't plumb it in, it bleads off air. Just put a small filter on the end
Doesn't sound like cables as it would be doing it all the time. I would start off with changing the gear box oil first. ATF is a good oil for sorting out gear box problems
Should have got your self some water wetter http://www.redlineoil.com/Products.aspx?pcid=10
got a good weekend planned ep82 meets ep85
turbo Grant replied to weeman's topic in Lifestyle General
Get cracking then man. You got a good car to do it on. -
You got a stock actuator?
Is she fit? Was thinking about this the other night lol
Ill have to get some snaps tonight. Been sorting some bits out on it. You guys will have to wait a bit haha
Went and got a new car Saturday. Got it back on the road yesterday. Can't wait to finish work and drive it home. Any one for a green starlet?
It's us who have it wrong working lol if you don't have to work then why the hell should you
I would take a feed off each runner as well. Will give you a more stable map sensor reading
It's an inline filter for the map sensor. Also acts like a damper so you get a more stable signal. Found this on eBay quick, item number is 370845934303
That's just a inline filter. Can get them off eBay for pennies
Lol, next week!
Good car, looks clean. I'm in no rush to do a clutch on one again haha
quad light indicators same as twin lamps?
turbo Grant replied to EPnick22's topic in Exterior Design
The mkII have a amber insert behind the clear front lens. That cam be removed to make them clear. The mk3 have a amber front lens -
Sounds like you have mkII indicators as they are clear. Quads have a thicker border round them and they are amber lenses. But mkII indicators will fit with quads -
Decided to change the radiator as the one I had was full of salt from my old car. Now I have a 3 core rad and shroud. Just in the middle if making it all for haha
- 676 replies
- garrett
- livesports
(and 3 more)
Tagged with:
Was in my k reg 93 mk2. It had oem LSD rear strut bar and that from factory I think
Sound like a kid again
turbo Grant replied to Chrishoughton1989's topic in 4E-FTE Engine Discussions
I've had 150 out of my old GT when it was Basicly stock. -
The vac pipe is usually just a bleed back from stock boost valve. Not sure why it's running into the bulk head?
Usually on the negative side of coil for rpm pick up
