2479 -
It will work but wether it fits is a different matter. Just need to strip it out and try it really to be sure.
Well got the alternator back on the car after work today. Turned out the cj pulley was to blame. So machined that so it won't happen again. And this box turned up at work for me today
Shorty's ep85 " The Mountain Goat"
turbo Grant replied to shorty's topic in EP85/EP95 4WD Progress Blogs
I need to get my ass up to yours and sort this build out! -
Maximum power for a N/A e series engine.
turbo Grant replied to Chris Green's topic in Lifestyle General
They do lack bottom end power. But that's how it is with little engines. Best thing to do is lighten the fuck out of it get it and ballence. Ported head with cams high comp it and rev the tits out of it on itb. Make it into a big bike engine. Nothing's better than revving a gszr 1000 to 12k cars are slow! Haha -
★ Amjad's Sutāretto ッ ★ HKS exhaust fitted! :D
turbo Grant replied to Amjad's topic in EP91 Progress Blogs
looking cleaner than when i last saw it -
I've put an fte inlet on mine and power comes in at about 4.5k and just wants to rev right out. definly neds a higher rev limiter! need to get a stand alone on and have a play -
Well was running the car up today. Was all going sweet. Up to operating temp. Have it a good rev up then it cut out. Engine was turning over proper slow was having cam sync errors coming up on the lap top. So I stripped it out to this Found nothing. Was expecting to find the cruise cams snapped or some thing lol Turns out the fucking alternator seised up haha got it back together a bit quick with the aux belt off and still starter great. Panic over!! Will have to wrestle the fubared one out tomorrow and replace with one of my spares. Got loads of bits done over the weekend. Got my battery kill cable mounted and in Just need to buy the plumbed in fire extinguisher kit so I have the other pull cable. Just thought I should have posted a pic of my welded in baffles I made for my rocker cover. Can wait till its next off as with my set up. Removing the rocker cover requires removing my timing belt cam pulley
Welcome
Welcome along. Also good listen to the manifold for blows. They can crack and on the head where the exhaust manifold bolts on the end can crack. Look if the rear discs have gone red on the edge. Sign of binding callipers if red
Try pressing the hazard button a few times
Hello from a lonely Paseo owner...
turbo Grant replied to RichardKSavage's topic in Welcome New Owners!
Welcome along -
Water pump impeller hitting water pump housing
turbo Grant replied to garrygt's topic in 4E-FTE Engine Discussions
Not heard of this before. Some one might have put the wrong pump on in the past and changed the housing that bolts to the block for a different one. That all I can think of -
Moorley's GT (will be forsale/breaking shortly)
turbo Grant replied to Starbo Moorley's topic in EP80/EP82 Progress Blogs
Do this ^^^^^ can't throw it all in now. -
Can just get them to put an 14mm banjo fitting on the other end and use the banjo bolt you have. I think it's 14mm an hows
That's oil feed for turbo. Looks like an-3 or poss 4. Need to measure the diameter if the treads to be sure. You got a bb turbo then
Getting road mapped by me on the way to work for mot. And ill get it down the dyno to set the tourque curve up and top end fueling. Got a dyno 10mins from my house now
Things are looking good for jf2. Hope to have it in for mot in the next couple of weeks. The welded in cage will be fine for road use. Going to be funny climbing out the thing in a parking space haha
Can you put the bolts in first with it loose and the do then up? What's the spec of the turbo your using?
Matt1878's Varis V - Now For Sale **
turbo Grant replied to Matt1878's topic in EP91 Glanza Progress Blogs
Nice and even, can you get hold of a pressure tester for the rad cap? -
It's better than walking. But scooters are seriously gay
I had my limited edition derbi drd sm with chrome frame and black and orange plastics and black wheels and under slug exhaust as standard. Was proper spec'ed up bore bit bigger carb and what not. When I passed my bike test it was still the fastest 50 in Winchester even with 2 people on. Still got it haha. Plan to get it back on the road one day
Gt35 crew should be fun. I'm thinking track time as well
Pillow ball top mounts (Bearings)
turbo Grant replied to akyakapotter's topic in Chassis & Suspension
Would be a cheaper way of doing it. When i got a price on some from tein they were £70 a side. -
Could always take one apart and take it to a bearing supplier? -
Have you tryed contacting d2. I know you can get them from tein if you email them
