2479 -
Taggys EP70 Boxy, Forged TD04, 5E-FTE
turbo Grant replied to Taggy's topic in EP70 & EP71 Progress Blogs
Looks like I won't be needing my big trout I might have to slap you with a small one just for thinking about selling up! This is going to be crazy on track with taggy behind the wheel haha -
Nice route for the boost pipe! I wanted mine throw there but want to get it on the road without creating lots of work for myself. Will be looking forward to seeing the bigger picture
They have twin bulbs! I've never seen any like this before as well
We shall see how it goes... But finally got round to finishing my cold side pipe off. So now I have 1 hot side pipe and 1 cold side pipe
I would be checking the ignition system. Could be the coil pack giving a poor spark under boost
Southampton/Hampshire Meet Up!
turbo Grant replied to DanTheGlanzaMan's topic in Southern Central Region
Most of us in this area don't have our cars on the road yet -
I'm in 2 minds to get this done for Japfest or not. I'm edging on not getting it done for fest. Going to take me a bit of time getting all the bits how I want them. Because once it's on the road it won't get much done too it till I break it. I've got it running but will get a vid once its running on all 4 cylinders. I'm not firing on cylinder 2. Bank D injector isn't firing will be sorting this very soon
I've yet to drive my car. Coming up to 2 years I think?
Good stuff this car needs to live -
Haha ill sort a little vid out soon. The avcr reads bang on with my ecu Smoking
It's alive!!!! Some how?!?!?! Got a fuel leak an oil leak and a water leak. But apart from that things seem ok. Will sort the leaks out today as they are only minor easy fix ones. The ball is really rolling now
Try second hand breakers. Or take it all out and put a nice small universal heater box in.
that's standard to have 2 boards one bolts to the top the other to the bottom. I find after plugging an ecu back in it takes a few days to settle down
2 Times TOTB FWD Champion!!!
turbo Grant replied to Mad Mike EP82's topic in EP80/EP82 Progress Blogs
Looking good. Bet it does go well -
I welded it disassembled and weld a bit one side then the other side. Try not to get too much heat on one area as the weld will try and straighten out as it cools
I'm not fussed about what power it makes. I just want to drive it
Been told by both people who ran it it better than a td05 20g for spool
Got the exhaust sorted now. Adjusted down pipe and made new front section up Was a bit awkward doing it with the car on being quite low off the ground but got it done
Well it's back in its place
Why do I keep looking at this for the paseo!
Shorty's ep85 " The Mountain Goat"
turbo Grant replied to shorty's topic in EP85/EP95 4WD Progress Blogs
Not far now. The engine is plenty run in haha -
On after market diffs the wheels will still spin the same way
Indicators not flashing just staying lit
turbo Grant replied to yaristurbo's topic in MOT & Maintenance
You could test it with side light bulbs first if you want. But does sound like you need to get a 50w relay for it. Pretty basic the indicator relays with 2 pins. Not a lot you can get wroung -
You just using a 2 pin flasher relay? Make sure you have power going to it from ignition supply would t have thought the watts should be an issue really. Should be 21w in there
