Sudden
    98
Everything posted by Sudden
  1. Sudden
    Timing
    Crank should be at tdc not 10 degrees.
  2. I've been looking to do that rear wiper mod, I've seen yaris owners do the exact opposite and wad wondering if the gear from the yaris could just be swapped with the starlet wiper gear.
  3. The "4e-f" (carburetted 4e) distributor has weights on the shaft like a traditional carb motor, with a vacuum advance and a built in igniter setup with the coil... Its basically an efi distributor but with mechanical advance instead of ecu controlled timing. The 2 pin distributor plug is the same, and the only one necessary. Bike carbs are more expensive and tedious than efi. I ran mikuni bs36 (yamaha fj1100) bike carbs on my 4e-f motor for a while, mated perfectly to a cut tubular intake manifold. Was part one of my experiment to prove the efficiency capabilities of constant velocity slides with individual throttles. But the needle that meters the fuel worr into the emulsion tubes causing them to run like garbage aftet a time, and the cost of replacement parts for the carbs came to over 80usd for each slide, and over $1000usd for a set of new/refurbished carbs. I Purchased 04 yamaha r6 itbs with injectors, tps, map sensor and harness for $19 usd. Fuel injection, retaining the constant velocity slide application to continue my project. IG @c.n.a.b. for picture documentation and any questions.
  4. My compression is 262 251 258 261. I have blow by, I was wondering if not having the oem pcv setup would cause irregular crankcase breathing (trying to breath in and out through both crankcase vents simultaneously?
  5. *seconds Adam's post* new oem valve springs, valve clearances well within spec. Unless it's a 5e bottom end that hasn't been balanced and strengthend don't go over 8
  6. Usdm* distributorless ignition 5efe headgasket is 0.5-0.6mm metal. Specifically usdm, my JDM distributorless 5efe had 5efhe pistons and a normal sized non metallic head gasket. It isn't worth the effort with a 4efe. @Jeremiah
  7. Compomotive cx 13x7 et6 are sexy 😀. Nice stance, looks the same height and stance as my ep82. Had to run stiffer springs to stop rear arch rubbing on hard cornering (couldn't find rear are setup)
  8. Hehehehheheheheheh. love it. What management are you running?
  9. Not with itbs and a good tune, the cylinders aren't fighting each other for air like a single throttle plenum manifold.
  10. My 1991 ep82 came with the 4e-f carb engine
  11. USDM toyota tercel 5efe distributorless obd2 5efe headgasket. 11115-11090 http://www.amazon.com/KP-1025AMZ2641-Cylinder-Head-Gasket/dp/compatibility-chart/B001EFSPJI
  12. Pointless trying to use the oem ecu. Vacuum reference for fuel will give you poor drivability and mileage. At 0 to 5% throttle(tps) your map sensor will think you went from 30inhg to 0inhg(full throttle) use a full engine management and tune in alpha -n or a hybrid alpha n. https://youtu.be/5jvmLzHtWDY
  13. Take your time shifting and you'll be fine. Selector forks and shafts, can be iffy. Gear width won't brother you till you are putting down lots of torque throughout decent tyres. N/A boxes have final drive ratios ranging from 4.312, 3.546 and there maybe a 3.700( labeling key changed between 95-96 starlets and tercels, so difficult to say for certain.
  14. *wipes up drool* good heavens.
  15. Displacement, compression, air, fuel. No fun without good gear ratios though. My setup is a 5efe block (skinny rods), with 4efe pistons, a usdm 5efe 0.6mm metal head gasket. Shaved 4e-f/4efte head (stronger valve springs), 5efhe cams timed to the 4e mark( aftermarket cams are too expensive where i'm located). 5efhe header and full piping, minus the cat(replaced with an oval 2inch resonator. Yamaha R6 itbs from the early efi model. Megasquirt 1 ems. C150 -672 (3.546diff) gearbox removed and replaced with a C150 -642 (4.312diff). What I would do differently if/when I rebuild: Blueprinted and balanced rotating assembly with forged rods, custom forged pistons to match the 4efe stock piston, but with deeper valve reliefs, ported and polished head (preferably uncut), higher duration/lift cams and uprated valve springs, custom header. Methanol injection. In all honesty this build would be a waste of time for anyone who isn't fully dedicated to seeing it through. Such dedication cannot be found if peak hp numbers are an end goal.
  16. Lovely
  17. Black wire for the horn? 2 airbag wires and 1 horn wire usually go through the airbag clock spring,so you would need to replace the horn wire if you remove the entire clock spring assembly. Assuming you needed a horn?
  18. Part number/spec/info on the 6 bolt lsd?
  19. 5e block? Are the cams timed to the 5e mark? Retarding the cams slightly by timing them to the 4e mark shifted my powerband very nicely, (fhe cams in an n/a build)
  20. I wish I had center caps for my StarMags. 😩 does your ep8* carry hub-bracket-caliper? Or just hub-caliper? Mine are vented aswell but theres no bracket so I cant experiment with different caliper/disc options.
  21. Nice progress! The JBW Starmags are awesome wheels (i have them on my soliel s) but they limit you if you plan to upgrade your brakes later on ;)
  22. Good to hear man! 😁
  23. Sooo, these for sale or nah?
  24. best stock exhaust evar!
  25. Drill/slot new holes into manifold flange for temporary fit/use? (gasket over flange could be used as a template)
