Hoping I can get it sorted too man, it was skimmed when I had the forged engine fitted, didn't do it this time round tho - thoroughly cleaned both contact areas though
  • Replies 595
  • Created
  • Last Reply
Top Posters In This Topic
Wheres the oil coming from? Aye area of the leak?
Cant really think of the headgasket leaking oil unless its totally shagged or its on wrong.
Did you replace all the seals, cam seal, dizzy O-ring and cam cover gasket?
its def coming from underneath the head man - all the other seals are holding up fine, I checked all the channels for flow on the headgasket none were blocked
Si mate i hate to be the bearer of bad news but after a hg fail its best to check the block face too. as the block may need a mild decking too :( this is why my whole engine was in bits a year or so ago. whip the head off and get it checked n maybe reskimmed :) you maybe ok. also while the head is off check the block face for level. I've not heard of an athena gasket failing so is more than likly deformation of a surface. chin up bro shes a beast!!! Dont give up when your so close! You will regret it and then just come back and start again with another starlet haha we all do! Persevre mate!!
Thats what mine was too but a sudden rush of boost leavin the two faces via the space provided by the streching head bolts is plenty of potential for warping :( can be fixed though. You know starlets si, if it can happen it always does lol. Leave it a few days then wrap up warm and crack out the tools :) dont let jeff down! Hes come too far now
Indeed, it would be too easy if they just worked all the time. :p
Keep the faith Si! :)
thanks wallace and shorty got a local mech gonna take a look hopefully but if it means engine out dunno if i can be arsed with all the faff, head off is one thing
Si(gh)
Rubish man!! Head off is half the engine out already!! Your talking 2-3hours tops from that to take the engine out! I've had engines in and out of starlets so many times its common palce for me now haha. if you brake jeff because you cant be arsed to take the engine out then
a.) i will slap you with a wet fish! (and dont think i wont)
and
b.) do you think stripping the car would be less hassle? Parts dont just fall off lol and the engine would then need to come out any way thus contardicting the very reason you justified braking the car!! Ironic eh?
You're mean (but I love you lol), I know but I've had enough there's other issues i can't be arsed with and this would be the straw that broke the dromedaries spine
I've got a guy coming to look at it with me on saturday to see if I've forgotten anything obvious and if not removing the head for skimming
