  • Replies 775
  • Created
  • Last Reply
Top Posters In This Topic
Nah you don't want loud exhausts -- My HKS system just burble when Idling, then when you open it up on the road it sounds good! There's a 1.4 MG ZR on my street that's about 10x as loud as mine, sounds good, but just too loud!
The OEM exhaust route is torturous! That centre box looks quite small -- That's my lowest point on the car... always scrapes ove speedbumps unless I'm doing 1mph
cheers guys. loving the sound its great when it gets warmed up.
yeah, its a rea bad routing, but i think its pretty good for backpressure plus that backbox of mine must be really restrictive as on starup it sounds standard!
centre box? nah, got them to do away with that!! only things on the system are 1) the cat, (not for long!) 2) the flexipeice, 3) the back box.
ok a lil update, changed my plugs yesterday, (cheers graeme mate ;) ) what a difference! feels so much smoother, the old ones looked ok, but o well. (gaps look bigger on the old ones though??)
also had a peek inside the top mount to see if there was much oil floating around in there, as i remember someone saying its a good way of seeing if the turbo's throwing out any oil.
theres a little oil, but seems ok! what do you guys think?
also got a few little bits thru the post, but only fitted one for the meantime, just something small.
hks oil cap, matches my bov too!
another update should be on its way in the week, as im off all week, so i might give it a good clean for some pics!
Sweet match on the HKS oil filler cap Rich.
Might be worth cleaning your top mount if possible? Every little helps lol.
Keep up the good work.
Week off eh? Lucky bugger!
Take it easy
Joz
just sein all your new mods, yea those rims look exceedingly better than what id thought they look like, and i changed my plugs on my old v after a major service making a big difference,
looking good mate :)
I'm gonna do a whole ignition overhaul on mine soon -- Dizzy cap, rotor, plugs and leads... I'd say coil too but there £90 from toyota!
sorted the cat out the other day...
before....
check out the heavy restriction
during....
after....
feels loads better after a ecu reset. i found no increase in boost though... which was a bit strange as i know afew people that have had an increase.
the tin cover for the cat was a pig though, one of the bolts seezed on and rounded off so i ended up spending an hour cutting it off!!
Does it feel any quicker?
I wanted to do this to the SR too but it won't pass MOT so its not really worth it for us n/a boys (Unless you've a spare cat)
Also that tin cover is always a b**tard!! I've had to snap the last two off due to the nuts being fcuked thats why we need a new one right now!
well i doubt it'll make as much difference for you n/a boys, but it does feel better all round really. faster is a bit of a overused term, it defo feels much more responsive, and spools up faster... its also much louder!
  • 3 weeks later...
did a little bits to it the other day. fitted my old ecu back in after the no difference the 96 ecu made.
also got this off ebay.
its a lamco 43mm boost guage. i suspected my greddy one wasnt reading right. so fitted this. nice little addition with its own rubber pod.
also ive noticed that the rubber bonnet seal at the front of the bonnet could be restricting airflow to the airbox intake.
so i cut a small length off to allow cold air flow to the airbox. made a nice difference.. it actually started boosting higher too!!
