  • Replies 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
The 5EFHE has thicker rods and a higher lift exhaust cam compared to a 5E-FE. Everything else is the same, of course the rods don't matter as I'm forging it anyway.
Yes mate I can't wait either! I had an annoying hesitation problem with the Glanza and finally sorted it today, I had a feeling the vacuum pipe to the MAP sensor had too many feeds going from it (boost gauge, EMB and AVC-R) and I was right. So when the engine is out I will get some new vacuum nipples threaded in the back of the manifold. I also need a new AVC-R as the buttons on mine are quite sticky and are beginning to annoy me.
So much to do, such little time.
ace buying a full paseo is the way forward ive done the same!lol also some of the 5efe engines also have the thicker rods. if yours does let me know as i might want them if my new engine has the thin rods? not too sure yet though until i drop the sump?
  • 1 month later...
Just a few goodies waiting to be fitted..
No idea when they'll be fitted though as there's not enough hours in a day, I miss the car loads! :(
  • 3 weeks later...
Idrees, this car is absolutely sexual - nothing more needs saying (unless I mention that reading the majority of the build thread was awesome and inspired me) ;) awesome work!
  • 1 month later...
Cheers guys :D
The 5E is ready to strip and machine:
The build will hopefully progress this month. I have a few other parts to be fitted which I will show next time. :)
Nice to see you are still plodding along with this matey :) didnt think you had time to wipe your own arss these days lol with the expansion of ID-WORKZ etc!.
Keep it up dude love this project :)
What a car, just sat and read the whole build thread! Been meaning to since reading the banzai feature. Can't wait to see what power this makes when the 5e is built, mapped etc. What management are you gonna run?
Thanks for the nice words guys. She currently has an Emanage Blue but I may upgrade to Emanage Ultimate for now. Maybe better management at a later date :)
The block and bottom end parts are now at the engineers for machining. I also now have a lightweight Fidanza flywheel so I'm happy with that :D
The following work will be carried out:
Block rebored, decked and notched
Crank polished
Bottom end fully balanced
Hopefully it will be back in a couple of weeks. Just need to do something about the head now.. :)
very nice update any plans for a the head? turns out thats the expensive bit :p
think u should get a emu :p and on an unrelated note have u seen my for sales thread :p
still waiting on a reply to my pm by the way just w hen u get a chance and are u able to supply blueprint stuff? like cv joints and what not cheaper than camskills?
  • 2 weeks later...
  • 1 month later...
Right then, sorry about the lack of updates. I just don't have enough time to work on the car these days.
So, the engine is back from the machine shop. I just need to get the cylinder head sorted before assembling the engine, even if it's a simple rebuild with no port/polish. No pictures of the engine, but I cleaned 6-7 months wort of dust off the car and gave it a rinse.
New parts include:
-C52 gearbox with Quaife LSD
-Greddy Emanage Ultimate (nothing amazing, but better than the Blue I currently have)
-OEM armrest complete with brackets
Along with the usual engine build parts; Athena 1.4mm headgasket, ARP headbolts, OEM oil pump & gasket set, thermostat, water pump, timing belt kit, oil pressure switch etc.
There will be some changes on the exterior too, but that's probably after the new engine is in and running.
