PaulStarletSR Posted July 25, 2013 Author Share Posted July 25, 2013 Coming along nicely! y thank you.more updates to come. im workin all the time so only gettin the odd hour on her here n there but itl b worth the wait once I've sorted the body work Quote Link to post Share on other sites
Ryan5793 Posted July 25, 2013 Share Posted July 25, 2013 awesome work bud, nearly there! Quote Link to post Share on other sites
PaulStarletSR Posted July 25, 2013 Author Share Posted July 25, 2013 awesome work bud, nearly there! cheers mate. the biggest mechanical thing left to do is fit the GT brakes and tighten up the exhaust then make sum bottom brackets for the FMIC. then its bodywork (wee spots of rust due to the last owners utter fuckin stupid retarded ideas on how to "mod" a car. i actually hate whoever he is) and get fresh tyres. only daft wee things then. Quote Link to post Share on other sites
Ryan-11 Posted July 25, 2013 Share Posted July 25, 2013 Coming along nicely Paul Quote Link to post Share on other sites
PaulStarletSR Posted July 25, 2013 Author Share Posted July 25, 2013 Coming along nicely Paul thanx bud! i need 2 wee vac pipes for the power steerin to sort the idle hunt issue then i can steam into the rest. u got any spare bud? Quote Link to post Share on other sites
Patches Posted July 26, 2013 Share Posted July 26, 2013 thanx bud! i need 2 wee vac pipes for the power steerin to sort the idle hunt issue then i can steam into the rest. u got any spare bud? Looking good mate, i might have some if they are attached to the old steering rack. Will have a look for u tomorrow Quote Link to post Share on other sites
PaulStarletSR Posted July 26, 2013 Author Share Posted July 26, 2013 Looking good mate, i might have some if they are attached to the old steering rack. Will have a look for u tomorrow thanx mate! aw sweet!thatd b awesome if u had some! Quote Link to post Share on other sites
PaulStarletSR Posted July 29, 2013 Author Share Posted July 29, 2013 i smell updates.............. Quote Link to post Share on other sites
PaulStarletSR Posted July 29, 2013 Author Share Posted July 29, 2013 right then, once again thanx to bucketep91, he done me a crackin deal on these 2 and threw in the vac lines i needed to hopefully cure the idle hunt issue. the vac lines are on and the SR's batterys chargin as we speak for the moment of truth 2moz! Hopefully it cures the issue! New bits.....il update 2moz if the engine runs smooth Quote Link to post Share on other sites
daniel_g Posted July 29, 2013 Share Posted July 29, 2013 Getting close now man !! Quote Link to post Share on other sites
PaulStarletSR Posted July 29, 2013 Author Share Posted July 29, 2013 aye bud! only needed the boost gauge as mine wouldnt light up so thot fuck it lol start her up 2moz n hopefully she purrs like a kitten Quote Link to post Share on other sites
bucketep91 Posted July 29, 2013 Share Posted July 29, 2013 I thought ud have fitted them wen u got home. Will take u 2 mins lol.Good luck 2morrow! Quote Link to post Share on other sites
PaulStarletSR Posted July 29, 2013 Author Share Posted July 29, 2013 I thought ud have fitted them wen u got home. Will take u 2 mins lol.Good luck 2morrow!lol was gona leave it till 2moz, but couldnt resist lol the battery wasnt strong enuf to start her, so 2moz...... Quote Link to post Share on other sites
bucketep91 Posted July 29, 2013 Share Posted July 29, 2013 Hopefully it does the job mate can tell your itching to drive it, your face when u had a shot of mine the nite said it all lol Quote Link to post Share on other sites
PaulStarletSR Posted July 29, 2013 Author Share Posted July 29, 2013 lol ano bud, even tho it was only a wee car park, was good to hear spool n feel a wee bit of boost! cheers mate Quote Link to post Share on other sites
PaulStarletSR Posted July 30, 2013 Author Share Posted July 30, 2013 right then, have a quick shite then out to try this wee fucker out! Quote Link to post Share on other sites
PaulStarletSR Posted July 30, 2013 Author Share Posted July 30, 2013 ok so I've put on the powersteerin vacs and checked every other 1 and all is well but then i start her up,took a while for her to start again but when she did, STILL got the idle problem please help because im gettin proper pissed off at what should be an easy fix Quote Link to post Share on other sites
Socks Posted July 30, 2013 Share Posted July 30, 2013 u tried unplugging the TPS yet? Quote Link to post Share on other sites
PaulStarletSR Posted July 30, 2013 Author Share Posted July 30, 2013 u tried unplugging the TPS yet? 4got all about that 1, il go try that now Quote Link to post Share on other sites
Socks Posted July 30, 2013 Share Posted July 30, 2013 4got all about that 1, il go try that now Leak would cause a high idle.. but it wouldnt cause the revs to go up and down like that... IMO... If it is a leak tho there is a dead easy way to find it... Take the boost pipe off and put your hand over the throttle body... It will suck. If it cuts out. Its not a leak.... If it doesn't cut out the revs will get lower, you should hear a sucking noise from where the leak is... Quote Link to post Share on other sites
PaulStarletSR Posted July 31, 2013 Author Share Posted July 31, 2013 another wee pic Quote Link to post Share on other sites
td04 glanza Posted July 31, 2013 Share Posted July 31, 2013 3.42 AM Paul you have got issues mate and not just with the sr. Quote Link to post Share on other sites
PaulStarletSR Posted July 31, 2013 Author Share Posted July 31, 2013 3.42 AM Paul you have got issues mate and not just with the sr. lol a finishd work at midnight so couldny sleep lol Quote Link to post Share on other sites
RobSR Posted July 31, 2013 Share Posted July 31, 2013 It would hunt if its a vac line 100%. I had the problem before. Turned out it was one coming off the bottom of the throttle body. Check all those and the map sensor vac also. Aswell as cleaning out the ICV etc. Quote Link to post Share on other sites
PaulStarletSR Posted August 2, 2013 Author Share Posted August 2, 2013 Picked up these 2nyt..............Compomotives! Quote Link to post Share on other sites
