stock 5efhe compression is 9.8:1, however, the 4ef/ 4efe piston dome is almost twice as tall.... My aim is to use oem parts to 'modify' mine. not sure how accurate my calculations were but it should be somewhere in the 10:62:1 compression range. cylinder pressure doesn't tell me much about compression ratio because my stock 4efe is 230/ 240 across each cyl and its 9.6:1 cr. so I'm not going by that. interesting info on the crank, I guess that would be cheaper than a full knife edge job, and would be a kind of engine insurance. Water injection would allow you to run ignition timing you wouldn't normally be able to on lower octane fuel, you could use this to push the boundaries and go for more power, or as a safety/ eco mode to run leaner mixtures without the temperature problem. Also our pumps are not labeled so for all I know we are getting piss water in our tanks, will mainly be a safety for me if/ when I get it setup.
More videos where we can see the tach ans odometer clearly please. I keep watching that video over and over :D
  • Replies 698
  • Created
  • Last Reply
Top Posters In This Topic
I wouldn't really think there is a need to run water injection in the UK, I would use BP Ultimate fuel, which is 99ron I think. I wonder why the 4e-fe was not labelled a 4e-fhe by toyota, as far as I am aware the 'h' stands for high compression.
that does go really well for a n/a,fooking well done.
Cheers man, finally going good!
Not much of an update, but I have finally clocked 1000 miles since the rebuild.
  • 2 weeks later...
Another tiny update and a to do list!
Was coming home from a meet on Sunday night and disaster struck. Car just died on the motor way. Turned out to be the TPS.
Well a picture paints a thousand words.
On with the solution to the problem. As TPS are hard to come by, I had to make do with what I had. In the case a Triumph TPS. Did a bit of research on autodata (shown below) and modded it to suit.
It looks untidy, but it's doing the job for the time being.
Anyway onwards and upwards...
To Do List
Change oil and filter.
Wash engine bay.
Remove, polish & refit ITB's
Paint TB brackets
Purchase and weld AN fittings to rocker cover.
Strip and polish rocker cover.
Polish Fuel Rail
Polish Catch Tank
Polish distributor bracket
Fix sensor for aftermarket water temp gauge
Clean all silicone hoses with Autoglym
Tidy up ground wires
Purchase shiny bolts for engine bay
Tidy throttle cable
Begin wire tucking & tidying.
Repaint PAS pump
Remove unused brackets in engine bay
Remove charcoal filter
Repaint Gearbox
Paint radiator & expansion tank brackets
Clean & Paint bonnet catch
Paint battery stay
The above should keep me going for a while!
Awesome build! Don't know if I've missed it but did you ever RR it and get a figure?
Cheers dude. No, it hasn't been on a RR yet. Planning to get it setup properly then take it to the RR. This will be the first place it will be posted.
Cracked on with the to do list today.
Started tidying up the wires and tucking as best as possible. Not going to do a full tuck, I simply don't have the patience.
Tidied the fuel a vac lines up too.
Stripped an old rocker cover and began polishing. Will have it done by tomorrow night.
ITB's are coming off tomorrow to be polished. Got some stainless bolts to freshen up a few things.
Photos to follow.
Didn't do a thing today, apart from getting a new TPS.
But......
Saved an EP80 from the scrappers. It's not mine, so won't give too much away, but it's going to a fellow enthusiast. Picking it up tomorrow, fitting the front bumper then going on a bandit run with no mot or tax.
Edited by chrisgreen1993
LOL at the bandit run :thumbsup: Enjoy it haha!
  • 3 weeks later...
Not much of an update, but seriously considering taking the ITB's off. Just started a new job in the city centre 9-5 and rush hour traffic is a load of toss TBH.
Got my rocked cover mirror polished, will add photos later.
Got some optional extra goodness is the pipeline too!
I Wouldn't be driving anywhere near that city Centre around rush hour. Train no good to you? I get it down to Queens every day, wouldn't look back haha.
(Feel like a translink advertisement!) Lol
It cost the same to fuel the car give or take £20 as the train would cost me. I'd rather be sitting in my car rather than next to a sweaty stranger. I get free parking too, so it's not so bad.
I'm working on the Lisburn road, not too far from queens.
