MISS,STRESS >>> mister koni yellow
  • Replies 411
Posted Images
got her home and after some checking my pump died on me also i am reading 18volts when cranking over ??? is that not to much ????
ordered an uprated 255l from ebay for prezza so that will go in next week
There is a fuel regulator behind the glove box on a GT. My car died when I first got it and would only start sometimes, after changing the pump and fucking around for hours. We put in a new wire between the fuel reg and the pump and this sorted it out straight away :thumbsup:
missstress is back up and running :) :)
but it wasnt without any problems polarity was marked the wrong way round on the new pump i could hear the pump working but car would not start
dam i got a bit confused ha ha 2 hours later i figured it out and rewired the poles and wham she started
then another problem accured the pump plug was getting freaking hot it was the blue white pin ( + to pump ) that was shorting out so depinned them and soldered them together with a 7.5a fuse socket in the line for safety works wel and dont heat up anymore :) :)
Inside radius are a fucker with only basic tools, eh colin :L
tell me about it ha ha i really nead to get some better tools for this sort of work belt sander is next on the cards to get joint faces strait ha ha there a fucker to do by hand !!!!
  • 3 weeks later...
wel bit of an update on the ct18 setup it works ( HARD ) just as i thought it would . also its compound now on the air intake /compressor side as u guys told me thanks guys :) , boost it easy controlled now and much more stable on low boost ( oem actuators ) i am seeing 1.2bar !!!! ha ha ha ha :) :) but i have a feeling there not fully synchronised yet a tat more boost then the other and i think its due to it being a
ct9a and a ct9 b slightly differnt size turbos
so now i will need 2 adjustable actuators ( or go external x2 :( )
buy 2x turbo speed sensor kits ??? ( where can i get them cheap ?? and / or similar device ?? )
so this will be coming of the car again today till i have those parts sourced ( could be a while )
