thanks for reading it dude, thats some undertaking!
And thanks for the kind words. Its had its ups and downs and been very difficult at times, but its quite gratifying at the minute that it can just sit in the garage whilst I source assorted bits and pieces, and fine details to tidy it up, and not worry about will it be ok for work in the morning! i can take it at a leisurely pace, and the best part is, MOST of the hard work and big investment is behind me. Now its about getting her up to scratch and MOT worthy and enjoying the Blitz set-up!
Picked up some nuts and bolts and self tappers from work this week, so pedals will be firmly mounted by the weekend!
Phil.
  • Replies 5k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Update
Pedals securely bolted up last nite, including a touch of graphite grease. That just leaves mounting the footrest to sort out.
Spoke with Monty on Saturday, work is progressing on the rocker cover, it's in primer already, so I'm gonna have to see about some fresh oil seals, rocker nuts and PCV shortly.
Current spec list to serve as an updated reference point as I realized it was out of date whilst discussing spec lists with a colleague this morning (Momo mats and pedals removed, OEM pedals, Glanza footrest and Ultra leads added):
Exterior
Smoothed front bumper cut to fit FMIC with black mesh
TTE splitter
De-badged and smoothed bonnet with bonnet raisers
Crystal clear headlights with Ring Xenon bulbs and Glanza headlight adjusters
Late spec Glanza indicators with Silvatec bulbs
OEM headlight protectors
Crystal clear side repeaters with Silvatec bulbs
Ring front fog lights
Ariel removed and smoothed
Door locks removed and smoothed
Bump strips removed
Mirror back plates colour coded
OEM wind deflectors
Glanza side skirts
Glanza rear spoiler
Glanza rear bumper
Zisco OEM-style ducktail spoiler
OEM Carat tail lights
HRF rear spats
Bootlid de-badged and de-wipered
Medium tint on rear windows
Lower rear foglight
TRD windscreen decal
TRD rear sunstrip
Engine Bay
Glanza 4E-FTE engine conversion
WEPR FMIC
Custom s/s exhaust with HKS Silent Hi-Power end can
NGK Iridium spark plugs
HEL braided clutch line
Hi-Attain lightweight throttle pulley
Smoothed fuel rail
SARD oil cap
SARD magnetic sump plug
Tuning Developments oil catch can
Tuning Developments reservoir covers
Ported exhaust manifold
Blitz decat
Blitz SUS air filter
Blitz K1 turbo
Blitz ECU
Blitz SSBC
Blitz top radiator hose
Samco lower radiator hose
Samco intake pipe
Honda Civic half sized radiator
HKS adjustable actuator
GReddy Type 2 dump valve
Carbon filter canister and pipe work removed
CJ Performance lightweight alternator pulley
CJ Performance lightweight power steering pulley
CJ Performance lightweight crank pulley
Smoked clear cambelt cover with 4E-FTE engraving
(GReddy / Grex oil filter relocator - TBC)
TRD engine mounts
Blueprint clutch
Blue silicone hosing
Twin Alpha horns
OEM headlight motors removed
K&N Rocker Breather
RW Developments blue silicone oil return
Ultra spark plug leads
Interior
Corbeau Carrera bucket seats
Willans 6 point harnesses with Willans harness pads
280mm Bride-replica steering wheel
Autogauge Rev counter w/ shift light
A-Pillar pod with Autogauge Volt gauge and Autogauge Oil Pressure gauge
Apexi EL1 Vacuum gauge
Apexi EL1 Boost gauge
Apexi EL1 Exhaust gas temperature gauge
Apexi EL1 Oil temperature gauge
Apexi EL1 Oil pressure gauge
Apexi EL1 Water temperature gauge
Pivot Speed Meter
SR clocks w/ blue bulb covers
TRD carbon effect dial surround
TRD carbon effect centre console
TRD carbon effect window switch surrounds
TRD short shift kit
Glanza cup holders
Honda S2000 start button
OEM illuminated ignition surround
OEM Rhiostat switch
OEM passenger footwell storage box
OEM armrest re-trimmed in grey alcantara
OEM din blanking plate
OEM rear transmission cover (EP82)
OEM Toyota Rescueman MkII
OEM pedal set
Glanza footrest
Momo carbon effect handbrake
Momo carbon effect gear knob
Momo carbon effect gear level gaiter
Momo door sills
Aftermarket cupholders w/ storage tray
Relocated horn button
Second rear window heater switch used as front fog light switch
Rear interior stripped
OEM sound system removed
Seatbelts removed
Headlining removed
Rear interior wire tuck, including boot-pull cable and petrol flap pull cable
Rear washer piping removed
Door open sensor wiring relocated inside B-pillar
Cobra Alarm
Glanza V front door cards
JDM Emergency Flare
Handling
Cusco front upper strut brace
Cusco front lower strut brace
Cusco rear upper strut brace
Zisco C-pillar bar
Ultra Racing Room Bar (EP82)
Jay’s Garage B-pillar bars
Whiteline adjustable rear anti roll bar
TRD front shocks and springs
Koni rear shocks and springs
Volks 5/4s / Speedline Safaris
Braking
EBC Yellow stuff front pads
EBC grooved and dimpled front discs
EBC Ultimax rear pads
HEL braided brake lines front and rear
Glanza rear disc conversion
Cusco BMCS
Toyota 5.1 fluid
Painted calipers (Hammerite Hammered Black)
Phil.
Edited by Nanglebadger
Spec list for this is like a book!
Footrest sounds like a pain :(
Edit: just realised I've never commented on this build. Read through it a few months ago, just watching it from the shadows ever since. Haha
Edited by vizzioarts
Awesome thanks John!!!! I need to learn how to do that with my phone!!!!
Cheers Liam. All credit goes to the extremely talented Monty as he is the man behind the awesome! I can't take credit for the work, I spoke with John about how he did his, brought my paint into the house to warm up, then thought I should just let a pro do it in case I fucked it up. Cue Mr Monty!! The colour he has been able to match as closely as possible to the powder coated inlet mani I bought off Starbuck last year, so should all tie in pretty well hopefully once all fitted!
Couldn't be happier with how it looks, just need to arrange collection which I have had to delay due to other commitments this week. Big thanks to Crooks for acting as delivery man also, saved me getting lost in the wilds of County Armagh!!!!!!!!!! lol.
I've also spoken to Monty about the rear floor. I'll just leave that sentence hanging there for a good while until I can pursue it further ;)
Phil.
Update
Rocker cover washers have arrived, epicly fast delivery from Id-Workz!
Collecting the rocker cover and inlet mani from Crooks this evening after work all being well, so shall be refitted this weekend. Those in the know, watch the Instagram feed for pics!
Phil.
