I turned down the oem disc so it's a hub. And fits inside the fag discs. And machined a couple of mm off the caliper carriers. Re-drill caliper mounting bracket and you have a 256mm rear disc set up.
  • Replies 288
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 weeks later...
ohh my god!! what did you do!!!! No hole in the piston but hole in the valve :p
abuse ? NOT GOOD!
But anyway how does the piston rings looks like....
When i had retarted ignition ( premature ) not only the valve;s were bend but 2 piston rings cracked and 2 piston rings turned out blue duo to the heat + pistons ring land was busted. But they came out 0 zero pressure during compression test... on cil 1 and 2.
Mayby check them if your unsure.
just changed the head and got it back together again a day or so later. Reused the mls head gasket with wellseal. The valve might have just gone because of a carbon hot spot. The Pistons look pretty good still. Will re-ring soon as the bored look a bit glazed and it uses a bit of oil.
Got round to putting the mid spoiler on today. Always fun drill holes in a perfectly good boot. Needs another respray as the paint match is crap. Will do that when I paint the sides of the car.
28D06EBA-45FD-40C3-9358-2D017260D190_zps
4575D530-1AEF-4C03-AA53-0EDC8F600968_zps
  • 2 weeks later...
  • 3 weeks later...
Do you live in Andover mate? Must be you as there aren't many of these kicking around. I've just moved down here and was driving around today when I drove past it :) looks awesome mate
I did strip the exhaust housing off and all was good :)
I recon a carbon build up on the valve cased a hot spot on the valve. It did let go on a 5th gear pull. After redlining 4th.
  • 1 month later...
Got a nice list of bits to do on this before fest2
Needs to play with arches, play with some camber on the back, sling one of my forged 5e's in, swap over my spare ep82 box with cusco diff, weld an extension in on my down pipe, fit 550cc injectors, finish plumbing in my oil cooler. Get a new wideband sensor and then road map it. Will be fun as I'll still using it as my daily lol
  • 2 weeks later...
  • 5 weeks later...
So had a good time at japfest2. Clutch was playing up and boiling my clutch fluid and making my pedal disappear. Was quite interesting going to down shift into a corner and nothing!
95C5C402-F163-48B8-9E2B-6D26106CF31A_zps
601D7C11-27C3-4DF1-9D16-0163ACF80EDF_zps
5AA3B411-107D-4273-9583-EAE75A82E2ED_zps
Few pics that I got tagged in on fb
  • 2 weeks later...
So I finaly got round to sorting out the eml on this. Was coming on because of the ep82 wasn't getting a vss. The ep71 si clocks I fitted didn't have a vss. So I stipped old ep82 and my clock down to see what I could do. I'm happy to say the the ep82 vss fits In my clocks with only drilling 1 hole and wiring.
79ECE01D-7D93-4D7B-ADD0-2968AA43378B_zps
BC730D36-E946-4D72-810C-A945913477FE_zps
8DA38F5B-0CF2-4F95-89A6-CB1B99ABF3C1_zps
62BB36AB-4029-43B4-A5F9-63B79711CC3D_zps
2151E163-DE1E-4B14-B8C8-96C7695F397B_zps
4FD3333F-B6C1-4C8C-964D-417A597F9323_zps
I get eml light on mine because of vss can't figure out how to fix it pisses me right off :(
Get a second had cluster and swap the vss over. Job done :) sound like a JAE job lol
