  • Content Count
  1. Get the lenses with new seal from toyota for £24 each thats what i did
  2. Paul morgey Stapleton
  3. Id go for the rain sports then i think, i havnt tryed them personally but a few people on here rate them, the other option is the likes of a goodyear aysemetric 2 or bridgestone potenza of some description, which should have good alround road holding, as for track ad08's are £75-80 a corner r888's which are more track biased are £110 + which are on par with the yoko AO08 track tires for a similar price ;)
  4. I've found my cars got worse for tram lining since fitting my lsd box, i was going to get the geo setup and see if that helps, as far as tyres go, I've had toyo t1rs and on a low powered car there fair dry or wet until they wear down obvs now have yoko ad08's and these are superb in the dry and pretty desent in the wet but only if you can keep them warm which is quite hard lol
  5. Technically yes atmosphere is a bar but most sensors for cars will be set to read 0 at atmosphere as its neutral and works as a standard to go by so 3 bar would be fine upto 44ish psi which usually more than enough
  6. 30-32 it depents if theyve been replaced, i have both on mine, and i can manage mine with a standard socket in a halfrauds tool kit ;)
  7. Had the pleasure of meeting him last night, sound guy and very clean car, a nice addition to the UKSC family!
  8. On my 4age it leaked after i had it powercoated, chipped the paint off where the oring sits as it had made the oring stretch more than it should and cause it to split when pushed in the hole, replaced it and its been fine ever since. Any oring close to the size u need will be fine toyota want about £3 for something worth 2p lol
  9. Get it priced up for a repair and see if she'll pay, if not go insurance or live with it. Is it visual when the boots closed? If not id leave it i forget my cars had a slight shunt since straightening it out!
  10. if not camskills sell a rebuild kit for both sides for about £50
  11. this might be of some use to a few members on here whether it be for buying/selling or just identifing what might be inside your gearbox, note the stock lsd below is NOT for a EP and i do not know what they look like, but a OEM LSD box can be identified in the wiki section here http://www.ukstarlet...&id=2&record=21 all info is taken from the toyota levin/trueno forum, http://s15.zetaboard.../6706511/1/#new I know these are from a levin gearbox but they use the same gearboxes and diff's but with different bellhousings so they are interchangable STD Open STD (not necessarly true f
  12. Not sure if its a repost but quite Amusing />http://mofarahrunningawayfromthings.tumblr.com/
  13. For wheel fitment 54.1 on all iirc is the technical size For brakes early gt's have 54mm up to 94 i think! Later gts glanzas and na's have 55mm (brake size only as the hub is stepped)
  14. Welcome along, hope you enjoy your stay
  15. Ahh cool, cant wait too see it, be good to have more fellow ep owners locally!
  16. Yea if the weathers poor then i wouldnt bother, you got your car on the road or you got a rent-a-wreck for a bit?
  17. Theres usually a few people down there from 7:30 8 till 10:30ish, mostly jap enthusiasts but not all, good bunch of people tho
  18. I was there at 10:30am last year on the friday and there was people there befor me by then, just make sure you know which plot your heading for lol
  19. Congrats on the safe arrival dude, I've heard some horror stories from some americans shipping cars!! Now you need to get yourself down thetford mcdonalds on a wednesday night ;)
  20. Duno if this is the case on yours but when i fitted my coilovers i didnt apply any weight to the hubs when doing up the two bolts onto the shock so when lowered back down they had positive camber, jacked it back up slackened them off and lifted against the disc lightly with a jack, then tightened them up, dropped it back down afterwards and even set in the middle of the camber adjustment i had slight negative camber ;) P.s cars looking awsome as always
  21. Cheers guys appreciate it Finished wrapping my hks manifold on saturday so just need to pick up the cat and then take it to the garage and have them fitted to my exhaust and she should be set for snetterton tuesday the 21st
  22. ahh im on my phone so cant see, ill scope it out this evening cheers ;)
