  1. I've seen Carbon fibre sheet doorcards before
  2. Dont happen to do any n/a manifolds for 4ages?? Lol
  3. I might be wrong but on that link i posted they mentioned just adding a washer to sit on the shoulder and bolt it together with all the old stuff.
  4. My understanding is There should be be a shoulder on the shaft of the shock that should sit against the bottom washer on the top mount. Yours has punched through the washers and now isnt doing its job, Hence the nut isnt clamping the washers and top mount together
  5. Youve way too much thread sticking out the top of that shock from what I've seen. Have a look here might have a similar issue to whats said near the bottom http://austarletclub.com/index.php?/topic/17287-rear-shockie-top-m
  6. Thats because my cars in the background
  7. If the matrix is flowing then theres zero reason it shouldnt blow warm air. Maybe check the air ducts are all operating. The center 2 usually only blows cold unless you have the dial to face only by the way
  8. If i had to hazard a guess id say it would under read with the UK odometer.
  9. Jack the car up at the front and bleed the coolant system with the heaters on hot. Failing that, whip the pipes off the heater matrix and stick a hose on the end and turn it on. That should flush it out.
  10. Its not for me personally as i dont have a 4e/5e but it might be something that people would want.
  11. 4efte manifold flanges and common turbo flanges so people could make there own? Might interest a few people
  12. Myself with a black SR i would keep it stock colour, just because it was the only UK starlet available in black. If i had another car/model id be willing to change, especially with some of the colours that modern cars are coming with. Im actually quite a fan of the new focus RS blue
  13. I had a laugh earlier. Oem alternator from amayama for my 4age was nearly £1000
  14. Where did you get an alternator for £85?
  15. Theres a required post count for sales. Youre currently on 3 posts so got a bit to go. 0 for cars 50 for parts 25 for general goods 150 for a breakers thread
  16. I had to get custom poly mounts made for my 4age ones, £60 each wasnt fun and now the dash board is like a dog on heat when the idle drops lol
  17. Yeah drilling it will he fine. A good impact gun is great for breaking them off too
  18. Try amayama.com youll need the part numbers and need to add import tax which i think is 20% of shipped cost and a handling fee £15ish to the final cost.
  19. Not any more, had 2 sets at one point lol
  20. Are you torquing it up to spec?
  21. No idea what you're on about...
  22. ❤ some cracking shots already!
  23. Pregreased
  24. These fit TTE lips as well
  25. Replica Gel Oem center cap inserts. These were made to fit my stock speedline centercaps so best hope you still have yours, there are 2 styles and 4 sets of each so i cant imagine these will hang around long! Remaining. 2 lower case. 2 upper case. Due to change very quickly OEM style is the italic CAP's ones and the lowercase style is another design taken off the interwebz Price per set of 4 £19 posted including all PP fees or collection at JAE for £17.50 **tte stickers forsale in separate poat**
