TrisK Posted June 19, 2013 Posted June 19, 2013 265 as I'm remember yours being a bit lower cause of the autobox last time Quote
Socks Posted June 20, 2013 Posted June 20, 2013 270-2801.4bar on a 4e... They all make the same power... Unless uve done summink out ordinary... Quote
5T4R7ET N/A Posted June 20, 2013 Posted June 20, 2013 (edited) . Edited June 20, 2013 by 5T4R7ET N/A Quote
Chris_GlanzaV98 Posted June 20, 2013 Posted June 20, 2013 291 looks sick ash ! Enjoy it when she is back might even see you down there mies just needs a map and a road Test now 6 months later !!!!! Quote
EP-Azz Posted June 20, 2013 Posted June 20, 2013 Makes me want more than 200 bhp now lol I reckon no more than 290 on 1.4 bar?? Spill! Quote
iamlegend Posted June 20, 2013 Author Posted June 20, 2013 cheers all and some pretty damn good guesses well done to lewGT .....................................................made 280bhp at 1.4 bar... picking up tomorrow so will be updating this thread with a hell of a spec list Quote
iamlegend Posted June 22, 2013 Author Posted June 22, 2013 (edited) well glanza is back home... me and brother went to go collect it yesterday from tuning developments was wicked wei trip! power is just incredible that is all! boosting 1.4 bar very smooth pulls like a mother fucking mad train..torque steering is nuts... got a lot of work carried out so here is the spec on it just gave the engine bay and inside and out a good clean was black haha good to be boosting once again TD ran in the engine along with oil changes and oil filter Stage 2 4EFTE Rebuilt Engine Specs:Wossner 74.5mm Low Compression Piston Kit with Rings and PinsScat 4EFTE Forged Conrod Kit with ARP Rod BoltsAthena 1.2mm Uprated Metal HeadgasketARP 2000 Uprated Headbolt Kit inc New WashersGenuine Toyota Full Gasket KitGenuine Toyota Oil Pump KitOEM Water Pump KitOEM Cambelt Kit inc Idler & TensionerACL Main Bearing KitACL Big End Bearing KitACL Thrust Washer KitFully Machined and Polished 4EFTE Bottom EndFully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard SpecBlock, Head and Rocker Cover Cleaned and Painted in our Tuning Developments Black and Silver Theme engine parts added:TD low temp thermostatpcv valve and grommetoem lambda sensordizzy cap & rotor armmagnecor 8mm leadsoil pressure sensorfuel filter turbo parts/engine etcrecon tdo4 turboTial external wastgateWEPR external wastegate manifold/screamer pipe and decatJ performance FMICTD fuel pump460cc injectorsrace tech water linesTD oil lineEMB/map sensor mapped to 1.4 barNGK spark plugssard fprRW oil cap and battery clampPurple hoses in engine bayoil breather filterblitz dual ebc1x powerflex engine mount whats next!!.... UPGRADED BRAKES ALL AROUND Edited June 22, 2013 by iamlegend Quote
