klyfax Posted August 23, 2013 Posted August 23, 2013 Two proposals. Do something about your silicone water hose to the turbo. The hose is going to be hard very fast, then it cracks and start leaking. Silicone and radiant heat is not good at all.And your cooler setup, you need at least 0.5" (1.5 cm) space between 2 coolers so the air can change direction and eliminate the turbulence. Otherwise the oil cooler would just block the air instead of passing through it. It will still cool the oil, but wont be very effective.Hope its readable :-D Its late :-DI like the FMIC and water cooler, looks like quality and very good. Looking forward for some video of it :-) Quote
jayc-glanza17 Posted August 24, 2013 Author Posted August 24, 2013 cheers for the advice..but its working well after a run yesterday it cools very effectively..and their is scope to over the oil cooler either side of its position, so its easily rectifiable if I find an issue with turbulence. Quote
klyfax Posted August 25, 2013 Posted August 25, 2013 No need to change something that works Around what RPM do you have full boost? Quote
jayc-glanza17 Posted August 26, 2013 Author Posted August 26, 2013 had its first run last night..and it sounds mental on WOT with the new inlet..and its much smother as your building boost due to the torque increase. water temps sits at a nice 86 to 88c in all driving conditions, raises a little on idle obviously but fan soon brings it back to 88 vey quickly. Quote
jayc-glanza17 Posted August 26, 2013 Author Posted August 26, 2013 so today I did a job ive been meaning to do for while.. removing the AC condenser.. so I got stuck in.. Then took quick snaps of the bay in the lovely sun.. Quote
jayc-glanza17 Posted August 26, 2013 Author Posted August 26, 2013 thanks chaps, goes well too, and cools nicely..in fact I think the 13 row oil cooler might b too much, might drop it down to a 7.. Quote
TrisK Posted August 26, 2013 Posted August 26, 2013 Looks awesome jay!You coming down to JAE? Would be good to catch up with you again Quote
jayc-glanza17 Posted August 27, 2013 Author Posted August 27, 2013 jae no matey..im at a charity supercar day for havens hospice.. will be hitting brands again before years out.. Quote
jayc-glanza17 Posted September 5, 2013 Author Posted September 5, 2013 been busy week as weather been pukka... first of all I sorted my coilovers out getting them all correct, had one top mount different to the other, so took them all off and re fitted, also cleaned them up.. obviously not running that much camber now, was just measuring to make sure getting similar levels each side..lol Then I took headlights out as rust had started to show behind the headlights.. .. then as my front bumper is poor, I decide to cut some air holes through it.. and got rid of the black part that used to have glanza badge on.. night time shots... Quote
russ78 Posted September 5, 2013 Posted September 5, 2013 jay mate everytime I see your front bumper it has less plastic on it, there will be nothing left soon Quote
jayc-glanza17 Posted September 5, 2013 Author Posted September 5, 2013 haha, cheers pal.. cheers for comments when you saw her tonight dude, means a lot.. Quote
russ78 Posted September 5, 2013 Posted September 5, 2013 haha, cheers pal.. cheers for comments when you saw her tonight dude, means a lot.. no probs buddy she is a stunning track weapon a lot of time and thought gone into it to get the end result and can only be truly appreciated seeing it in the flesh, even if they did turn off the lighting tonight ........ haha Quote
Beastmode panda Posted September 5, 2013 Posted September 5, 2013 Nice work man! A question regarding cutting the slam panel out, where/what did you do with the loom that is tucked under the top bit? Quote
jayc-glanza17 Posted September 5, 2013 Author Posted September 5, 2013 all cut mate.then re wired it along bottom crash bar... cheers lads.. hope to see you both at local meet before I take her off road.. Quote
Jamz Posted September 6, 2013 Posted September 6, 2013 What a build! looking so good. Need some videos! Quote
jayc-glanza17 Posted September 6, 2013 Author Posted September 6, 2013 id love videos, but my roads are so built up so wont be a good video..will take one when I hit brands hatch later in year.. in talks with zisco and my tuner, about building a race spec head for track racing.. Quote
NippyNippon Posted September 17, 2013 Posted September 17, 2013 Good work Jay. Looks epic mate.Dyno results are awesome too. It was rapid before the inlet and new cooling parts. Bet it flys now! Matt D Quote
Socks Posted September 17, 2013 Posted September 17, 2013 Get these results posted on leaderboard lad! Quote
jayc-glanza17 Posted October 7, 2013 Author Posted October 7, 2013 been a while since updated....basically been helping russ78 with his glanza..and in doing that, russ gave me a spare head, for my future plans... however I have fitted new canards that I acquired from this forum..http://www.ukstarletowners.com/topic/70961-what-are-these-canards-worth/#entry900242 so I set about refurbishing them and got them looking smart, then decided gloss black was going to be their colour..heres pics of them fitted... then had a little photo shoot with a friend Saturday night, some of you local people may have seen me driving around lakeside after.. I also blocked half my 13 row oil cooler off, so can run better temps on the road.. I also have done a 15 minute session rounds brands hatch, the td05 really is laggy is you use the right gear, and can corner quickly, but the cusco lsd really came into its own coming out of the bends, could really take a tighter line..just need to to understeer slightly less and I be happy with it.. future plans, build a race spec head, with billet cams, full custom roll cage and maybe a td05-20g..if that's a tad laggy, then I get another cosworth idle valve and use my omex's anti lag.LOL... Quote
russ78 Posted October 7, 2013 Posted October 7, 2013 Canards look quality mate more aggressive than the jam ones,massively appreciate all the help of late i can see the end now Quote
jayc-glanza17 Posted October 7, 2013 Author Posted October 7, 2013 I sort your water pump out Thursday matey..then hopefully it pass its test run, so you can start running it in properly.. Quote
