ste91
    4000
    West Mids
12555 profile views
ste91's Achievements
UKSO Elite
UKSO Elite (8/8)
  1. If using OEM Toyota sensors you will need the corresponding throttle body as well as the sensor and plug, as the mechanism that goes into the sensor is slightly different. I can't remember off the top of my head what the wiring is, but the diagrams are easy enough to find online, I did basically the reverse of this (3 to 4 pin) to use the 4 pin as my ECU requires a variable TPS. I think this is the standard 3 pin: top/yellow: TPS signal middle/brown and white: ECU ground bottom/black and red: throttle closed Your 4 pin auto TPS has a 5v feed which is now redundant, so you just have to check diagrams and see which order these three go.
  2. A whole year later and it's funny seeing this post come back up, car is finally getting a Link ECU fitted now, forged 5E and TD04, I sometimes consider posting a progress thread on here but hardly anyone bothers with the forum anymore
  3. Following this on insta, nice work, not seen one of those radiators on a Starlet before, is it a one off custom job or is it from another car? It's a shame hardly anyone posts on here anymore, used to love reading build threads like this and would post my own but it seems pointless when only a handful of people are going to see it anyway. The facebook groups are no where as good as what forums used to be!
  4. Get them from TB Developments instead https://www.tbdevelopments.com/products/polyurethane-shifter-bushes?_pos=1&_sid=e6dd2702c&_ss=r I only use TB Dev and ID Workz for parts, always been reliable
  5. Have you still got the bonnet, wings, and front bumper?
  6. Update again, turbo still not fitted and car not running 😂 😂 however the new engine (forged 5E) is almost ready and I've now got a billet TD04, only a standard 13T sized wheel but plenty big enough for what I want, going for a Link G4+ and Bosch 550cc injectors as well now
  7. Just came across this build again and realised I was one of the last people to post here back in 2018! Anyone know what happened to it?
  8. Always wondered what these are like, as far as I'm aware there aren't any LSD's available for them, so it's just open front and rear with a viscous centre diff is that right? How does it drive compared to a normal EP91? Notice any extra weight? What are the gear ratios like?
  9. Bought snap off steering wheel boss, Nikhil was easy to deal with, quick delivery and item as described. Cheers
  10. What was the total price if you can remember it? I've been looking at Garrett cores but those ITEC cores look good
  11. How much did you pay for the intercooler core? Also I have the same wastegate also bought from TB Dev and it comes with a variety of springs there's a chart online to show different combinations for whatever pressure you want
  12. I've made my own, don't have any pics but I'll try to explain, I used original feet on universal rails, all bolted together no welding required just a bit of trial and error. Get yourself a set of standard rails and some universal rails like this Cut the feet off the standard rails as mentioned, you might need to re drill the mounting point on the new rail to allow for the front to back distance on the feet. You'll also find that the universal rails are too narrow, so simply cut the release bar and you'll be left with two separate pieces to bolt in. Once you've done that you'll need to bolt your seats to the side mounts and put them in place and start lining everything up to drill the mounts. Then it's just a case of bolting everything together but it's not as easy as it sounds in writing it took me quite a while to get it right. Also if you are using the original seat belts, you will need to remove the buckles from the original seat, cut them down and re drill and bolt in on the inside rear seat mount. Then undo the seat belt and thread it through the belt holes, hopefully that makes sense but it means the belt is snug around you rather than coming over the top of the seat. At first I tried to simply modify the standard rails to fit the side mounts but it made the seats far too high so I wouldn't recommend wasting your time on that.
  13. Just spoke to my mate yea that's it he sold it to a lad in Wales, that exhaust used to be on my Glanza lol It's a standard 4EFE but everything else is 4EFTE as far as I can remember, inlet manifold, wiring loom, ECU, injectors etc... a forged 4EFTE would drop straight in but I'd advise getting it on a rolling road and checking the air/fuel ratio just to be on the safe side.
  14. I wonder if there was another owner in between then as this is definitely my mate's car it was him who did the 4EFE-T conversion, but he had cut the middle out of the bumper, does it still have the massive angled exhaust? It does look a lot better with the new bumper though it looked hilarious before, literally cut the whole front out of it and stuck the intercooler in there 😂
  15. I'm sure this is my mate's old car, has it got the front bumper chopped out for the intercooler?
