Nanglebadger Posted July 14, 2015 Author Share Posted July 14, 2015 (edited) UpdatePicked up some replacement rear inner plastics and front inner door handles from Jay yesterday, I'm very fussy so had to find some in very good condition. Also picked up the lower arms to start into the refurb process.And tonight after work swapped over the door handles.Before:And after:It's all in the small details.Phil. Edited July 15, 2015 by Nanglebadger Quote Link to post Share on other sites
Rich-k Posted July 14, 2015 Share Posted July 14, 2015 Looks great mate! Quote Link to post Share on other sites
Nanglebadger Posted July 15, 2015 Author Share Posted July 15, 2015 Thanks bud, nothing fancy, just trying to tie it all in together at the mo! Phil. Quote Link to post Share on other sites
Nanglebadger Posted July 16, 2015 Author Share Posted July 16, 2015 (edited) For my own records: Tidy engine bay - as done as it will beNew radiator bracket - doneWire in all Apexi gauges - done, just need to connect sensors for oil and waterFit oil filter relocator - ready to fitFix bumper support barCatch can needs emptied and wire wool replacedBoost controller needs replacedRepaint all 4 calipersFit harness crutch straps - can't be done, nowhere suitable/safe to mount toWeld holes in spare wheel wellPaint rear floorTires for VolksTires for Speedlines - doneNew bonnetFit anti-lift kitWax oilAir fuel ratio gaugeWideband gaugeFront ARBShorten the intercooler piping - doneFit powder coated inlet manifold - donePaint rocker cover - doneRepaint ends of front strut-brace and BMCSShiny recessed washers to tidy up engine bayAddress the seats - done New items: Source some replacement rear inner trims and new handbrake trimCheck CV bootsBlow out washer jetsNew suspensionRefresh lower suspension parts (arms, bushes, joints) - arms and bushes collectedNew number platesInvestigate exhaust mani optionsFlush out washer bottleFinish cleaning wheel archesHeat wrap exhaust And to keep me up to date because I missed a few things and have changed a few bits: ExteriorSmoothed front bumper w/ black meshGenuine TTE splitterDe-badged and smoothed bonnet with bonnet raisersCrystal clear headlights with Ring Xenon bulbs and Glanza headlight adjustersLate spec Glanza indicators with Silvatec bulbsOEM headlight protectorsCrystal clear side repeaters with Silvatec bulbsRing front fog lightsAriel removed and smoothedDoor locks removed and smoothedBump strips removedMirror back plates colour codedOEM wind deflectorsGlanza side skirtsGlanza rear spoilerGlanza rear bumperZisco OEM-style ducktail spoilerOEM Carat tail lightsGenuine HRF rear spatsBootlid de-badged and de-wipered w/ bungMedium tint on rear windowsLower rear foglightTRD windscreen decalTRD rear sunstripEngine BayGlanza 4E-FTE engine conversionWEPR FMICCustom s/s exhaust with HKS Silent Hi-Power end canNGK Iridium spark plugsHEL braided clutch lineHi-Attain lightweight throttle pulleySmoothed fuel railSARD oil capSARD magnetic sump plugTuning Developments oil catch canTuning Developments reservoir coversPorted exhaust manifoldBlitz decatBlitz SUS air filterBlitz K1 turboBlitz ECUBlitz SSBCBlitz top radiator hoseSamco lower radiator hoseSamco intake pipeHonda Civic half sized radiatorHKS adjustable actuatorGReddy Type 2 dump valveCarbon filter canister and pipe work removedCJ Performance lightweight alternator pulleyCJ Performance lightweight power steering pulleyCJ Performance lightweight crank pulleySmoked clear cambelt cover with 4E-FTE engraving(GReddy / Grex oil filter relocator - TBC)TRD engine mountsBlueprint clutchBlue silicone hosingTwin Alpha hornsOEM headlight motors removedK&N Rocker BreatherRW Developments blue silicone oil returnUltra spark plug leadsAnthracite and polished rocker coverAnthracite powder coated inlet manifoldInteriorEvo 7 Recaro seatsWillans 4 point harnesses with Willans harness pads280mm Bride-replica steering wheelAutogauge Rev counter w/ shift lightA-Pillar pod with Autogauge Volt gauge and Autogauge Oil Pressure gaugeApexi EL1 Vacuum gaugeApexi EL1 Boost gaugeApexi EL1 Exhaust gas temperature gaugeApexi EL1 Oil temperature gaugeApexi EL1 Oil pressure gaugeApexi EL1 Water temperature gaugePivot Speed MeterSR clocksTRD carbon effect dial surroundTRD carbon effect centre consoleTRD carbon effect window switch surroundsTRD short shift kitGlanza cup holdersHonda S2000 start buttonOEM Non-smoking ash trayOEM illuminated ignition surroundOEM Rhiostat switchOEM passenger footwell storage boxOEM armrest re-trimmed in grey alcantaraOEM din blanking plateOEM 5 piece mat setOEM Toyota Rescueman MkIIOEM pedal setGlanza footrestMomo carbon effect handbrakeMomo carbon effect gear knobMomo carbon effect gear level gaiterMomo door sillsAftermarket cupholders w/ storage trayRelocated horn buttonSecond rear window heater switch used as front fog light switchRear seats removedC-pillar plastics removedGlanza front and rear door cards and rear plasticsOEM sound system removedSeatbelts removedHeadlining removedRear interior wire tuck, including boot-pull cable and petrol flap pull cableRear washer piping removedDoor open sensor wiring relocated inside B-pillarCobra AlarmJDM Emergency FlareHandlingCusco front upper strut braceCusco front lower strut braceCusco rear upper strut braceZisco C-pillar barUltra Racing Room Bar (EP82)Ultra Racing Fender BarsJay’s Garage B-pillar barsWhiteline adjustable rear anti roll barTRD front shocks and springsKoni rear shocks and springsVolks 5/4s / Speedline SafarisBrakingEBC Yellow stuff front padsEBC grooved and dimpled front discsEBC Ultimax rear padsHEL braided brake lines front and rearGlanza rear disc conversionCusco BMCSToyota 5.1 fluidPainted calipers (Hammerite Hammered Black) Phil. Edited July 16, 2015 by Nanglebadger Quote Link to post Share on other sites
Nanglebadger Posted July 19, 2015 Author Share Posted July 19, 2015 (edited) UpdateRear plastics fitted, bit tidier now I feel and still plenty of weight reduction.Phil. Edited July 20, 2015 by Nanglebadger Quote Link to post Share on other sites
Westley Posted October 5, 2015 Share Posted October 5, 2015 Just scrolled through all 242 pages on tapatalk looking at this build... Over a few days span that is! And my god this car is god damn beautiful! The way it's transformed over the years is brilliant! I love it, oh thanks for cap too! At least an item from this car lives on in the same coloured starlet! Quote Link to post Share on other sites
Nanglebadger Posted October 6, 2015 Author Share Posted October 6, 2015 Haha cheers bud, yeah a few bits from her have gone on to live elsewhere over the years. She's still alive, started her in the garage last weekend again, and as always she fired first time and runs and responds well, just still weeping. But she's not forgotten. Phil. Quote Link to post Share on other sites
chris84 Posted October 7, 2015 Share Posted October 7, 2015 Just scrolled through all 242 pages on tapatalk looking at this build... Over a few days span that is! And my god this car is god damn beautiful! The way it's transformed over the years is brilliant! I love it, oh thanks for cap too! At least an item from this car lives on in the same coloured starlet!I couldnt find the forum on tapatalk what did you search to find it ? Quote Link to post Share on other sites
Westley Posted October 7, 2015 Share Posted October 7, 2015 I couldnt find the forum on tapatalk what did you search to find it ?I just typed in starlet, or uk starlet can't remember but it was one of them Quote Link to post Share on other sites
Nanglebadger Posted March 7, 2016 Author Share Posted March 7, 2016 Who would have thunk it, I appear to have found some motivation. Amazing what watching Fast N Loud and having Jay and Joel post some photos from back in the day will do for a buddy! Engine bay dress up kit ordered from JDM EPLower arms, BMCS, battery clamp and front strut brace ends are at the powder coaterNew MeisterR ZetaCRD+ being ordered after next paydayFront upper strut going to a mate for a good polishRear sunstrip coming off as its started to split The list: Wire in all Apexi gauges - done, just need to connect sensors for oil and waterFit oil filter relocator - ready to fitFix bumper support barCatch can needs emptied and wire wool replacedBoost controller needs replacedRepaint all 4 calipersWeld holes in spare wheel wellPaint rear floorTires for VolksNew bonnetFit anti-lift kitWax oilAir fuel ratio gaugeWideband gaugeFront ARBRepaint ends of front strut-brace and BMCS - in progressShiny recessed washers to tidy up engine bay - ordered Check CV bootsBlow out washer jets - done (thanks Joel!)New suspension - almost!!!Refresh lower suspension parts (arms, bushes, joints, track rod ends) - arms and bushes sortedNew number platesInvestigate exhaust mani optionsFlush out washer bottleFinish cleaning wheel arches - done Phil. Quote Link to post Share on other sites
glanzadude Posted March 7, 2016 Share Posted March 7, 2016 Some car build, how long you have the car now? Quote Link to post Share on other sites
Phil Posted March 7, 2016 Share Posted March 7, 2016 Super to hear of the progressPhil Quote Link to post Share on other sites
Rich-k Posted March 7, 2016 Share Posted March 7, 2016 So glad its being carried on mate! Quote Link to post Share on other sites
Nanglebadger Posted March 7, 2016 Author Share Posted March 7, 2016 Thats a good question Glanzadude - I originally registered on the forums in 2004, but I had the car before that as by the time I had registered it already had springs, exhaust, wheels and a bucket seat. Maybe since 2003?? Or maybe even 2002 - I'd need to check the previous V5 from when it was registered to my dad as he bought it from a colleague before I owned it. Thanks chaps, looking forward to getting these few bits sorted, especially the suspension as it will be a significant step towards being MOT-fit. Think alot of the motivation is coming from the NorthStars camp at the mo - being involved in the local group discussions and going to meets in the daily just isnt cutting it any longer. Being on the road is still a while away as we're looking to move house this year, but it should be a good bit tidier and closer to an MOT this year. Big thanks as always to Joel and Jay for the continued guidance when considering parts and changes, keeping a buddy on track! Phil. Quote Link to post Share on other sites
Hair Posted March 7, 2016 Share Posted March 7, 2016 Glad to see you've got some motivation again dude! Hope to see this on English soil one day Jack Quote Link to post Share on other sites
Nanglebadger Posted March 8, 2016 Author Share Posted March 8, 2016 Thanks Jack! Parcel of goodies received from JDM EP - unbelievable service, packed one day, delivered the next. And Matt being the big softie that he is, has thrown in a few pressies too! Seems I now have a lot of work to be getting on with, get this dress-up kit installed! Huge thanks to Matt for the super service! Phil. Quote Link to post Share on other sites
rob_bower Posted March 9, 2016 Share Posted March 9, 2016 This means nothing without pics. Glad to hear you have the bug back. Quote Link to post Share on other sites
Nanglebadger Posted March 9, 2016 Author Share Posted March 9, 2016 Agreed! I shall upload pics ASAP buddy! As always, plenty of photo updates via IG, #GaragEP Phil. Quote Link to post Share on other sites
Nanglebadger Posted March 11, 2016 Author Share Posted March 11, 2016 Silicone vacuum bungs ordered for inlet mani and throttle body. I'll try and upload a few pics over the weekend, especially if I make a start on the dress up kit. Cheers, Phil. Quote Link to post Share on other sites
Bluebear Posted March 12, 2016 Share Posted March 12, 2016 Good to see you posting about the wagon again!Continuing the quest to keep things tidy it seems! Quote Link to post Share on other sites
Rich-k Posted March 12, 2016 Share Posted March 12, 2016 Still no pics? Quote Link to post Share on other sites
Nanglebadger Posted March 14, 2016 Author Share Posted March 14, 2016 Thanks Nick! Sorry Rich - I got a bit sidetracked with spring cleaning the house with the Mrs half the weekend! But yesterday I managed to get a few hours spent on making a start on the engine bay dress up kit. Passenger wing, fuse box, fire wall, bonnet hinges, all done and inlet manifold mostly done. Was alot more fiddly than I anticipated! 2 of the 3 bolts on the drviers wing done....because I snapped the third, so that prick needs drilled and re-threaded :angry2: Pre-treated the power steering area in WD40 ahead of my next assault, hopefully get a few pics up once I've a bit more progress made fitting the kit! Waiting on the inlet mani vac bungs arriving this week too so should have that whole area tidied up and ready for pics ASAP! Phil. Quote Link to post Share on other sites
Nanglebadger Posted March 16, 2016 Author Share Posted March 16, 2016 (edited) Only took me an hour, but got the 5 bolts around the power steering reservoir and lines swapped out last night...NO BREAKAGES! Good old WD40 pretreat! Anyways, before Rich and Rob and Nick start booing me...some photees: JDM EP goodies: Dress up kit Shifter extension - I'll do some trialing with this and the TRD short shifter to see what I think: Snap off kit: Smellies: Some decals to add to the decal'd up cleaning products fridge: Some of the progress so far - out with the old: In with the new: And this is an oldie that has been posted before but is currently what I am working off as my inspiration: Plenty more washer and bolts yet to fit, along with the other JDM EP goodies. Parts are due back from powder coating next week, vacuum bungs should be arriving today/tomorrow, and once payday comes we should be ordering Meisters. In the words of Rob Bower: "Mega". Phil. Post-posting comment - wow, how shit are iPhone 5 camera pics. Think some higher res pics are in order, apologies! They looked better on my phone before I emailed them to myself for uploading! Phil. Edited March 16, 2016 by Nanglebadger Quote Link to post Share on other sites
Ollieh17 Posted March 16, 2016 Share Posted March 16, 2016 Awesome car, wouldnt trust those bosses as far as you could throw it. I had a similar one and was gash, worth spending more Quote Link to post Share on other sites
Rich-k Posted March 16, 2016 Share Posted March 16, 2016 YEEEEY pics!!! Looking great mate i love this car Quote Link to post Share on other sites
