Rob_bower's 242 bhp SR - Refresh and fueling upgrades.
  • Replies 1.3k
  • 4 weeks later...
right what with work and stuff and getting everythong ready for JAE ive not had much time to touch this although myself and ro55ifumi did have short session trying to match plugs up and we seemed to make some good progress. I also found time to strip the turbo kit down
Sods law one of the bolts sheered off
the turbo that was on the kit was screwed
but the seller had thrown in a low mileage one so it was just a case of swapping the housings over.
once ive swapped the housings over its off for a little bit of sprucing and the mani shot blasting so should look mint again then it will be time to source the final few bits and we should be good.
Rob
Shot blasting wont affect anything in fact shot blasting/peening is used to strengthen steel components, just dont get it in anything that has oil/ water in it or in any moving parts that will cause megger problems!
If ya need a hand with anything Rob I will be off work from satday and would be happy to help out!
yea exactly that rob, and cheers im back to work wednesday and there all weekend :( but if i get a day free i might actually have the build a starlet party i tried to organise last time lol
Right had a day off today so cracked on and had a very productive day.
First job was the manifold when stripping it down last week on of the bolts sheered off so it was drilled and today I finally got round to attacking it with the stud extractor. Surprisingly the stud extractor snapped :( so it was time for the back up plan drill and re-tap
The 2nd job was finishing swapping the turbo housings over ready to be freshened up.
3rd job, clean and paint the ewg and rotate the lid so the ports line up.
3rd job trial fit, for the turbo and the radiator to check for clearance. Some fit some don't.
It took a little turbo surgery to give the optimum clearance.
Managed to get the water lines and oil feed cleaned up to and in place, and mount the coil and ignighter to. Just need to extend some wiring.
More on Monday.
Rob
looking good mate! why dont ya cut all that lug off the turbo if your not going to use it for the waste gate it will look a lot nicer! in your VERY CLEAN bay. That post I put on FB wont work all that well with that rad lol dint realize you had a twin core rad I am still running the stock SR rad.
