Hi guys,
I've got a glanza 1996 model with the following modifications could people give me a rough idea on what it would be running ? Just would be good to have a ballpark figure before I have it dyno'd after crimbo Mod list:
Sard analyse ECU
Widebanded
FMIC hard piped in 2.5/3" pipe work
Stainless manifold (standard type)
Stainless decat
Full 5zigen exhaust system
Ct9 turbo @ .8 bar
Front mount air filter
Trd ignition leads and iridium plugs
Air con removed completely
HKS actuator
Ported waste-gate
There are other bits but non that I can see making a difference to the performance. Like tine coil over and what not.
Rough guesses are appreciated I don't need definite figures
Thanks guys I am surprised it is is as high as that ! What should I be looking to do next to see more gains ? Fueling,intake manifold? I am not sure where to go next thanks again for your input.
With more boost I'm sure you could see the 180mark suggested above without changing your setup.
Bit at 0.8bar I'm going to say 163hp
Majorly dyno dependant though
Phil
This looks like a competition on facebook and closest answer wins haha
160-170, depends on the health of your engine too! Up the boost a bit buddy ;)
Thanks for all the replies guys ! I would like to turn the boost up past 0.8bar but it seems that when I do (using blitz digital controller) it feels as if holds back between 4000rpm and 6000rpm it only seems to be noticable in 4th or 5th. What could the be ?
Probably a missfire.
I'd say 175+
My Glanza when it was running similar spec made 162hp @.75bar but I didn't have a plug and play ecu like you have. That will see you some good gains
