Cheers Zac, we'll meet up for sure once it's on the road!
Yep im well up for this matey, wouldnt mind having a good look around yours with all the kit on and not sat in the garage haha :rolleyes:
Im planning on hopefully organising a meet at J27 Birstall when the Krispie Kremes opens, would be a great place for a meet on the overflow car park of showcase cinemas!!
  • Replies 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
Sounds like a plan Zac. Prince I'll be back in Birmingham next month, I'll PM you when I'm there.
Managed to make a little start on the engine build this evening.
Picked these up earlier; Toyota engine gasket set, Toyota oil pump, Gates timing belt
Also picked up the head and block from the engineers. The block has been deglazed, so it's ready to build. After a lick of paint of course!
Cleaned up for paint
Piston ring gaps on the new build = 0.418mm
Ring gaps on the previous 4E build = 1.607mm ;)
While I was painting the block, my mate gave the pistons a clean up.
Block cleaned and painted
Cylinder head
Polished crank
And how the pistons look after a great effort from Usman (my mate who has literally build the whole car with me)
Just waiting on the bearings to arrive before assembling the engine, hoping they arrive today. B)
ill hold you to that ride buddy. havent been to any meets yet but will be doing so when my starly is back on oad. couldnt be doing so in my caddy van lol.
how much the machine wok on head cost if you dont mind me asking. really want some work done but dollar is tight atm. and more other things i wanna buy lol. also you still selling that custom inlet? am very tempted.
cheers
Great progress! I'll be damned if you're done before me LOL!
Get your ass in gear, I'm hoping to have the engine dropped in by the start of next week! Would have been sooner if I didn't have to spend the day in Wales tomorrow for a wedding though. ;)
cheers
I got the headwork done at a bargain price, usually would cost around £300 but a friend of my cousins did me a good deal. PM me about the inlet, I'm not desperate to sell it and would rather keep it however the money would come in handy.
Cheers :)
More new parts!
3E flywheel and OEM oil pump
Cam cover braided fittings
ACL bearings & piston compressor, which means the build can begin when I have some free time! :(
i truely admire your determination mate, i threw the towel in on my V once the mapping all went to shit :) i just figured some times that couple of hundred more £ is just to much! good luck on the new engine build dude.
Fuck me the ring gap on the 4e build, you could get a bus through that!! Who ever done that needs shot.
The ring gap you have went for, is that within standard specs?
Looking amazinnggggggg mate :)
Cheers Lewis!
i truely admire your determination mate, i threw the towel in on my V once the mapping all went to shit :( i just figured some times that couple of hundred more £ is just to much! good luck on the new engine build dude.
Atleast you're back with another one mate, cheers!
Awesome you got the bearings!! I wanna see you at Japfest!! :D
Should be there Inshallah! :D
With this being my first engine build I really wasn't sure about ring gaps. All a learning curve ey! The gaps on the new piston rings are the standard recommended ones (0.48 for top ring and 0.57 for bottom ring from the top of my head)
Did your pistons and rings not come with the spec sheet for the gaps etc? Still a sore one to stomach all the same.
Lets just hope this one is better. :)
Cheers Ed!
The engine is now built, huge thanks to my mate Usman and my cousin Shaq for giving me a hand with it today. Pictures from the process..
New engine spec list so far:
5E-FHTE engine
4E-FTE pistons on FHE rods
Mild ported & polished head
Valves lapped
Polished crank
ACL bearings
New OEM piston rings
New OEM oil pump
New OEM engine gasket set
New OEM 3E flywheel
New OEM distributor cap & rotor arm
New water pump
New oil pressure switch
Zep 1.2mm headgasket
ARP headbolts
Spec 4E paddle clutch
4EFTE oil filter housing
Polished cam cover (unfinished)
Smoothed & polished fuel rail
Custom inlet manifold
4AGE throttle body
Race-tech TD05 turbo kit
Jperformance FMIC
Fujitsubo Power Getter exhaust
good work on the engine fella! i cant wait to see what runs, as it was the same as mine apart from the headgasket,
Cheers Mark, I look forward to it myself. Not sure how much boost to run yet but I'll decide when it's on the road!
Auesome work iddy glad you are keeping this project going!!! ;) Ohh and just out of interest how come it has 4e on the cam pully?
Cheers Micky, the cam gears on the 4E/5E are the same.
I imagine it would be awesome on track on a TD04!
Engine won't be going in today as I'm waiting on a new timing belt. Gives is a chance to check valve clearances and fit the remaining few parts.
awesome work on building the engines a guide to building an engine would be awesome ;) hint hint lol
would love to build my own engine and see what kind of work is involved in it just wouldnt no where to start
Only one way to learn - give it a shot!
An update from last couple of days..
Sump and a few other bits fitted
Almost ready to fit
New flywheel
Fitted at late night!
She is running and sounds sweet! Went for a little drive last night and the alternator packed in so that's next to fix. :)
