  • Replies 298
  • Created
  • Last Reply
Top Posters In This Topic
Thanks!
I can post some pics of the progress in the diy section when i get it finished! :) Made them out of cardboard. It's not really a piece of cake if you want to do it properly, there's a reason they are not cheap! :D
Some updates. :)
She's standing on her own feet now! :p
The stance is quite ok. I'd like if it looked a bit lower, but the lowest part of my exhaust is now about 7cm from the ground...and I still want to be able to drive this thing. :D So here she stands for now. Wheels are not even about to scrape anywhere. :D I suppose with right offset I'd be able to fit even 16x8" rims without problems. These are 7.5" ET35. Even the rear is perfect and I don't have adustable panhard rod (and haven't rolled my arches!).
Heres the clearance
The lowest part is that flange. Otherwise I would take 1-2cm more off. Any suggestions how to solve than low hanging flange?
One more thing I'm actually really excited is my custom adjustable short shifter. :D
Haven't seen adjustable one anywhere, and yet it's really simple to make. Going to fit it during the weekend, can't wait to see how it works! :D
Edited by whitestar
Ok, couldn't resist again so had to get this thing going... :D
A few tight places here and there but I'll sort dem out! Have to fabricate fixings for the core and find a suitable silicone joint for my blitz bov. Also the piping hits PS belt so I'll have to bend the AC piping and cut the bumper.
Edited by whitestar
Nice one cheers. My AC has been removed but I didn't want to fit a cooler where I would need to cut the bumper support bar. Your car looks really tidy bud nice work :)
Cheers mate, appreciate it. :)
Had the same, don't want to cut any metal for fitting this. I'll work hard this weekend and try to get it on the road as soon as possible! :)
It's out and going like hell! :D <3
Got the FMIC installed perfectly after some bumper cutting. Had to cut it surprisingly much, but you can't see it when the bumper is on. Really happy with the result!
The FMIC sits really nice and tight and is aligned almost perfectly center. Really happy with the result and the bumper barely looks cut. Made the fixings my self, turned out really good.
The engine bay looks pretty much like this. Although had to put standard efi pipe back to be able to fit the apexi filter. More pics of the bay when I get it cleaned up!
The custom short shifter went on pretty easy. :) The shift is now considerably shorter but not too short. As the shifter is adjustable I'm able to make it even shorter if needed, but the feel is now really good and all the gears get in nicely!
Had to put quite a few washers to clear the stick from chasis. :D
My self fabricated pillar pod works like it should, and the gauges too! :) AFR is quite ok with the JAM ecu too, a bit to the rich side but that's how JAM ecus work. When boosting full to 1 bar in higher speeds AFR goes quite rich, even up to 10. At lower speeds it's healthy 11-12.5 on full boost.
And a few more pics to make sure there's enough of them! :D
Dirty as fuck (suits to it's behaviour :D) but nothing that can't be fixed! :D
Edited by whitestar
Took a few photos this evening. :) Lovin the car!
Engine bay is not cleaned yet, but had a quick wash for the exterior. Gonna get her polished propably next month.
Edited by whitestar
Noticed that I haven't done a full spec list, so here it is. :D I'm pretty sure it's all there.
List of mods:
Cusco Zero-2R Coilovers
16x7.5" ET35 TTE Grand Stand alloys painted RAL6027 with 195/40/16 Falken ZIEX-912 tires
OEM front and rear strut bars
OEM cup holders
OEM armrest
OEM wind deflectors
Optional extra 5 piece mat set
Hand brake leather gaiter
Bride Brix seats on Bride rails
TRD gear knob
Custom adjustable short shifter
Cam cover painted in RAL6027
AEM Uego wideband
Depo boost gauge
Custom fpr A-pillar pod
NGK Iridium spark plugs
Ultra ignition leads
Lonza oil filler cap
TRD rad cap
Removed boost restriction
ASH breather filter
Blitz Super Sound BOV
HKS actuator @ 1.1 bar
Slightly ported waste gate
Ported OEM manifold
JPerformance decat
Front mount intercooler
JAM ecu
Fujitsubo Power Getter exhaust
Apexi air filter
HEL brained brake lines
Tegiwa BMCS
5.1 brake fluids
Twin dark green Mitsuba Alpha horns
DLS Reference R4 - 2-way component 4" front speakers and tweeters
Pioneer DEH-4400BT head unit with bluetooth and handsfree
Beat BSW8ACT - 180 Watts Amplified Under Seat Subwoofer
Going to get her dynoed as soon as possible. :)
Edited by whitestar
  • 3 weeks later...
Got my car all polished up by a mate on saturday. :) Took a few photos and videos today. Here's a few of the photos. My brother is going to put the videos online some time soon, so I'll post them as soon they're ready.
Edited by whitestar
